Any pics of cars lowered with H&R 20mm springs?
Hi all
Just wondering if anybody has pics of their car lowered with 20mm H&R springs? (And with spacers ideally)
I had a search and found one from the front but hard to see clearance.
Any issues of scrubbing at all? I know there can be with the 40mm kit.
I ask because mine has been lowered with 20mm springs and has 10mm spacers on the front and it looks very close indeed!
Adam
Adam
Re: Any pics of cars lowered with H&R 20mm springs?
Mine is lowered on 20MM H&R and I don't have spacers. It is pretty low at the front and I don't have any scrubbing issues.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Previous:
Thanks mate! Looks good on those wheels, suppose they are probably a more aggressive offset than the standard wheels anyway hence no spacers needed.
Will see how I get on with mine and if it scrubs I'll have to lose the spacers
Wheels are 1" wider than stock with same offset hence aggressive look, spacers would be too much on mine. Good luck with fitting of yours
Previous:
Previous:
Yeah mine does seem to rub on the front under hard cornering or if I hit dips in the road... that is with a 10mm spacers.
I'm sure I read a few people with exactly this set up that said they got no rubbing.
Interested to hear from anyone with the same as me - H&R 20mm springs and 10mm spacers
It will be down to tyre sidewall profile.
E.g.....Pirelli look naturally stretched even OEM
Dunlops have a very "square" sidewall.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Mine is actually on Continental Contisport 285/30/21
Not had the car long at all but I bought it approved used from Audi and assumed they were standard OEM tires
It's a December 2015 facelift non PE model
They will be OEM tyres
Audi use a range
My point is all OEM tyres have different "profile" side walls
Some quite square some more rounded....depending on thins is whether you may get rubbing.
Audi use a range
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Ahh yes I see what you mean, they are quite square on the sidewall.
I removed the small plastic mushroom screw from the inner arch and that got rid of a lot of the rubbing, unfortunately I continued to test it and went over a bump with a bit of steering angle which managed to bend out my front wheel arch!!!
So yeah 10mm spacers need to go... Im amazed how low the 20mm H&R springs have sat the front end of my car. There is no gap at all now, I'm worried it may even rub without spacers if I'm turning hard and hit a bump.
Will test without spacers next... shame as it looks amazing now. The stance is awesome but can't put up with the rubbing
I thought my 40mm springs with 12mm spacers on the oem 20s were a tight fit but I haven't bent the wing. It is so close that if I sit in the car and turn the steering wheel side to side I can hear it rubbing the arch.
See what I mean?
That part where it touches on yours is where I bent it out, it's only a slight bend out but that was in one 30 minute test drive, albeit quite a bump in the road I wasn't expecting whilst turning. It made a horrible noise!
Mine doesn't touch like yours when stationary though. Does yours hit the arch badly under hard cornering?
I think I saw pictures of yours with the PE wheels and no spacers also, is that right? Do they still catch or are they ok?
Thanks for the input, appreciate it!
Adam
Adam
Yes that sounds like mine. With the PE wheels and the 285 tyres I can't run any spacers at the front at all. I don't notice it rubbing but there is no paint on the inside of the wheel arch so it must be rubbing slightly. But that is with 40mm springs.
Even with the screw removed there is a part of the wing sticking out still. Might be worth trying to bend that in a bit to make some clearance.
Users browsing this forum: No registered users and 188 guests
