Oil check always says fine. Not a drop used. Really?
Broken sensor or normal?
RS4 B8 chugged a litre every 1,000 miles.
Maybe you drive like pensioner mate:) car uses oil and normally oil level drops when you really using car:)
That's very normal usage, if you drive and use car normally it eats oil, for example I have 82.000 km on a clock and car eats oil normally, each year I change oil, doing 15.000 km per yearbrab wrote: ↑Fri Aug 18, 2017 6:50 pmWhen my car was delivered it was filled to the max...now 23,000km later is at 40-45%.
I did have 3-4 times 120mph-150mph sessions that lasted for about 20-30 minutes each (on Autobahn) and I generally drive about 100mph (car used only for outside of the city), as here in Croatia cops tolerate 155km/h without fines.
