High pitched noise
High pitched noise
Hi all so I'm back in an rs6 c5 .....
I have a slight issue and am trying to locate ...
On normal driving and heavy acceleration it sounds like the cars got a supercharger very high pitch whining noise and goes up with rpm then tails off and then comes back more noticeable after the car has warmed up ....from what iv noticed it gets louder sometimes on a right hand bend
Anyone experienced this? Any help appreciated
Re: High pitched noise
Could it be a pully or tensioner on it a way out? . Does it make any difference with the air con on/off ?
Does it do it when stationary ? Or only when moving? .
Does it make any difference with more electrical items turned on ? .
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
Aircon don't work needs gas will be doing that this week
I did suspect a pulley or tensioner but if I rev the car in idle it sounds fine
On load sounds like a supercharger
Could be a turbo issue or a boost leak from somewhere.
Is it using oil or blowing smoke on boost ?
Cheers Al
Possibly gearbox ATF cavitation. Check the level. Make sure the right strainer is installed.
Gearbox is shifting ok don't seem like any issues there ?
How do I check the oil level ? By removing the plug while car is running ?
No smoke blowing boost fine can hear the noise after the car has warmed up ....
Power steering maybe ?
Maybe power steering. Checked the level?
Checking the ATF is a bit involved. Depending on how DIY you are you might be better off getting a specialist to do it.
Eliminate the other possible causes first. Could be belt noise.
Does the pitch increase with engine speed or road speed?
Ok I'll give the rest of it a go.... can't hear anything on idle
Yes it increases with rpm soecially when I change gear down becomes more apparent ...
Silly question, you're talking about external of the passenger compartment?
You're not talking about amp whine from the radio are you?
If external, I'd go with power steering as Shopp suggested. Easy to check the level in the engine bay.
How long you had the car? Has it got the correct fluid in?
Hi chunky79 iv had the car about 2 weeks power steering fluid seems to the correct level with the green hydraulic fluid innit looks clean .... I have a slight whine while turning steering nothing major
Sorry yes talking about external noise
The only way I can describe it is sounds like a mini supercharger
Happens more at high revs and sometimes on a right hand sweeping bend
Also I have that horrible rattle on cold start which I believe is the cam chain on the back? Could that be the issue maybe wrong engine oil ?
What oil is best for our cars ?
I'm thinking the following
Chain tensioner
Power steering
Front diff
Aux belt tensioner
Cambelt tensioner
Chain tensioner
Power steering
Front diff
Aux belt tensioner
Cambelt tensioner
Does your neighbour have a cat?
- simonpoulton
Does it happen when in neutral?
Past: R56 Mini Cooper S
If you can get underneath and whip the aux belt off (there's an auto tensioner) this may help you pin point the sound. Could be the alternator.
Sorry, just read through again.
From your comment that it seems to do it under load, this is a good place to start. Check your intercooler/ pipes and vacuum hoses.
Users browsing this forum: No registered users and 223 guests
