Brake pipes corroded
Crazylarry
Post by Crazylarry » Wed Jun 21, 2017 5:30 pm
Recently had a minor service done at the stealers and a long list of other items that need 'urgently' fixing was brought to my attention. Amongst them was 'Brake pipes corroded signs of brake fluid leak'. For the pleasure of rectifying this they asked over £1400. Has anyone else had their pipes fixed and did it cost anywhere near this much?? Cheers.
ahoooga
Re: Brake pipes corroded
Post by ahoooga » Wed Jun 21, 2017 6:21 pm
find a local 1 man band type garage, probably cost £50-250, depending.
audi_driver79
Post by audi_driver79 » Wed Jun 21, 2017 6:34 pm
I'm having mine done at my specialist this year. Am expecting a big bill with the usual other stuff..
C5 RS6 Avant Mugello Blue, Original Springs.
2001 A2 1.4tdi 75bhp. Runs on fresh air!
Gripper1
Post by Gripper1 » Wed Jun 21, 2017 7:41 pm
Had most my brake pipes replaced as they were showing signs of corrosion. Was around £250 from what I remember, it's an easy job for a decent mechanic.
Ajc
Post by Ajc » Wed Jun 21, 2017 8:40 pm
Buy a half decent flaring tool and do it yourself if your handy with the spanners . If your not however then I wouldn't recommend touching the braking system. It's one of those things you really need to work for time every time.
Chances are the steel origial sections won't be available any longer ,so it'll no doubt be made up off the roll using copper where ever you go .so as suggested above ,Find a reputable independent mech and pay much less than the stealers
Cheers Al
04 c5 rs6 , Ebony Black, Bare shell repaint , Milltek's, PSS9's,Hotchkis Arb's,Gutted precats, hybrid turbos, Bosch 044 ,And an annoying EML light
Post by Shoppinit » Wed Jun 21, 2017 8:58 pm
Hmmm. Stealers... corroded brake pipes are a favourite.
Have you looked at them yourself?
Mɐʇʇ
Post by Mɐʇʇ » Wed Jun 21, 2017 10:36 pm
I've not bought new brake pipes in the last 20 years. Always just make my own. Costs almost nothing and they usually fit a damn site better!
simonpoulton
Post by simonpoulton » Thu Jun 22, 2017 8:26 am
I have done the front ones. Right firstly, the actual proper pipes from Audi cost peanuts, which is really surprising and were still available 1 year ago. Guessing they are probably universal to the A6 platform hence why so cheap.
The main challenge is the drivers side one (UK). The pipe run goes right the way through the chamber where the steering rack goes. Due to the shape of the pipe, I couldn't see a way of getting the old one out (unless cut) but more importantly getting the new one in, without removing the steering rack.
The steering rack has a bolt that allegedly can only be got too with a huge amount of labour, so needed another option.
I ended up changing the passenger side (UK) one with the proper part, and fixing the drivers side one with a length as described by AJC. Passed MOT and is not leaking. Someone suggested heat shrink as well to get that black OEM look for the pipe.
Past: R56 Mini Cooper S
Mɐʇʇ
Post by Mɐʇʇ » Thu Jun 22, 2017 2:16 pm
Just make sure it's not a halfords or laser 2943 one (or similar) - they're really <beep>.
Ajc
Post by Ajc » Thu Jun 22, 2017 4:41 pm
Or the Clarke version . I know what you mean Matt, I've tried the cheap and cheerful versions . Great if your only gonna use it the once . Any more than that the double flare die gets chewed up.
Cheers Al
Mɐʇʇ
Post by Mɐʇʇ » Thu Jun 22, 2017 5:12 pm
The ones I noted above (and the clarke one you note) - I actually found them dangerous. I couldn't get a single decent flare out of them.
My one is similar to this - http://www.ebay.co.uk/itm/Brake-Pipe-Fl ... 2548.l4275
Takes a little finesse, but always been happy with the results.
Ajc
Post by Ajc » Thu Jun 22, 2017 8:37 pm
They seem to wear out very quickly. I've had a few of the Sealey, Draper and Clarke ones . All were dogturd . Is that the vice mounted version Matt? I ended up biting the bullet and buying a snap on hydraulic version .
Cheers Al
Mɐʇʇ
Post by Mɐʇʇ » Thu Jun 22, 2017 11:09 pm
My one fits nicely in a vice - that's how I always do it. The ones I linked to above are a little different, but the principal is the same.
Actually - found a pic online of the exact tool I have. I dunno what brand it is, I bought it in Les Smith in the early-mid 90's I think.
With just a little care, reliably able to produce a decent flare. Always been tempted with one of the hydraulic ones, but I just don't do it regularly enough to justify the £.
Mɐʇʇ
Post by Mɐʇʇ » Thu Jun 22, 2017 11:12 pm
Oh! There we go - google image search. It's Motaproducts 'Easyflare'.
Nobby
Post by Nobby » Fri Jun 23, 2017 9:28 am
Hmmmm..... I've got a Clarke one. Good quality Automec copper brakes pipes and never had a problem.......
I'm no pro though!
Daytona RS6 Avant
Users browsing this forum: Majestic-12 [Bot] and 269 guests
