FS - RS6 C5 Avant, black , 03/52
For sale Audi RS6 Avant in black
2003(52 reg), 126k miles. Known forum car, previous owners Mr Grizz and Gingertoss...
Brand new gearbox and turbos at 80k, done by Unit 20, this was Grizz's own car.
Engine was changed at 65K.
Milltek non-res exhaust, custom sports catted downpipes made for me by Powervalve.
Unit 20 front big brake upgrade using the 390mm discs from a C6.
Standard rear brakes, plus spec discs.
Hotchkis front and rear ARBs.
MRC panel filters.
Wagner intercoolers.
Pss9s coilovers, no DRC issues.
Recaro CS seats retrimmed by MJ Interiors to match the rears.
RNS-E with 2012 disc, 6 disc changer in boot. Audi Bluetooth module.
LED rear lights.
August 2010 the car had a full service plus timing belt with all the rollers, tensioners, thermostat and water pump replaced. This was done at the same time as the gearbox and turbos. December 2010 MRC replaced 3 of the lambda probes and both of the EGT sensors. They also replaced the diverter valves, fuel pump, aux belt, roller and tensioner. They then mapped both the engine and gearbox. The car made 566ps and 812nm. (At this stage it had Milltek catless downpipes.) This can be seen on MRC's YouTube channel.
Previous owner Grant did the following :
May 2011 - new battery.
August 2011 - new front disc, pads and full service 89,758 miles
June 2012 - 2 new MAFs and ABS module refurbished
August 2012 - service, new rear discs and pads 100,058 miles
January 2013 – gearbox service 104374 miles
July 2013 – Oil cooler pipes and service 108,385 miles
February 2014 – service, MAF seals and drivers door lock 113,487 miles
The car has a hidden tow bar fitted by Unit 20. Only used for a bike carrier occasionally by Grant and never by me.
In my ownership in just under 3 years the car has had:
September 2014 - Unit 20 - Full cambelt change inc idlers, lever arm & adjuster, new output shaft and seal, new rear brake discs, new suspension bottom arms and n/s arms, new n/s rocker cover gasket, new radio antenna base - invoice for £3722
November 2014 - new alternator - invoice for £495
October 2015 - Unit 20 - service, new exhaust flexi joints fitted, replaced gearbox oil cooler pipes, gearbox service, repair to rear subframe mount - invoice for £1666
September 2016 - new window regulator, new battery - £394
December 2016 - MOT, 2 new coil packs and spark plug - £288
Jan 2017 - air con re-gas
April 2017 - new front brake lines, new brake pads & discs reskimmed - £1994
May 2017 - new coil pack, new steering slip ring to fix gearshift paddles - invoice for £359
Full service history. 2 keys.
Paintwork is generally v good, has a couple of minor bonnet chips and marks in the rear arches as is usual on these.
MOT December.
Goodyear Eagle F1s all round with plenty of life.
I intended this to be my daily but ended up keeping the family minibus as I couldn't bear the thought of my brood battering her too often. She has therefore only done 10K in 3 years. For sale due to spiralling cost of house extension!
Can be viewed in Cheshire.
£8500 ono.
Carl 07801 675092
MRC panel filters.
LED rear lights.
MOT December.
£8500 ono.
Carl 07801 675092
now - RS6 C5 Avant
previous - S4 B6 Cab in Venetian purple, Milltek & APR remap,
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
Re: FS - RS6 C5 Avant, black , 03/52
I am guessing seat are no longer Electric and Heated ?
That's a whole lot of properly-well-sorted RS6 for the money!
Correct on the seats, but on the up side they are lighter...
now - RS6 C5 Avant
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
Very nice indeed!
SOLD
now - RS6 C5 Avant
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
A6 4.2Q Sport
A3 1.8T Sport
80 Sport
Sad request - please post a pic of the Venetian Purple!!!
Greenslade
- 1st Gear
To meeeeeeeeee
Many thanks Carl
2003 RS6 Avant in Ebony Black/Silver Nappa - Wagners, Millteks, MRC Stage 2 map, Bosch 044, Sports Cats, Bilsteins, Hotchkis ARBs, 390mm C6 discs, Recaro CS, RNS-E, LED tail-lights, Goodyear Eagle F1s,......Porsche filler caps
Greenslade
- 1st Gear
Haha, great set of rules!!
Users browsing this forum: PritJutla and 83 guests
