TTS charged RS4, intermittent battery light
Regy53
Post by Regy53 » Tue Jun 06, 2017 7:46 pm
Howdy all
probably not many people with to much knowledge on this but today my battery light illuminated every 5 mins or so for about a second and went out... wasnt under hard throttle or anything.
i unloaded the alt so no lights or heaters etc and still did it, has anybody else experienced? could it be belt slip ? seems doubtful as the revs were not high or being driven hard , alt on way out? or maybe its a unknown feature of the supercharged cars haha..
Will talk with MRC this week i suppose
cheers
Ross
TTS Charged RS4 plus all the goodies
Dantheman84
Re: TTS charged RS4, intermittent battery light
Post by Dantheman84 » Tue Jun 06, 2017 8:10 pm
Just sounds like alternator is on its way out to me if you have a multi meter see if it's charging over 13.5v (about) then load alternator up turn lights on etc see if stays above 13v
RS4 kw v3 full miltek no cats :nogarors4:
Intake spacer deflap stage 2 flat shift launch
Kawasaki ZX10R 197bhp :audibash:
jonytek
Post by jonytek » Tue Jun 06, 2017 8:51 pm
What makes you think it's related to the charger?
BUILD THREAD
IG: @bad_rs_4
Regy53
Post by Regy53 » Tue Jun 06, 2017 8:54 pm
nothing really only the belt that drives the charger i assume drives the altenator :)
eliano
Post by eliano » Tue Jun 06, 2017 9:47 pm
I had similar on mine, flashed a few times.it then ate the belt whilst having a spirited drive which was scary.
Turned out the tensioner had a crack on the mounting point and was slipping, this then split and lost all tension , ate the belt into a million pieces .changed the lot and all good.
Take 2 mins to rule out, whip off the undertray and you can see if it may or may not be that.just a thought mate
RS4 B7 Saloon, Phantom Black , Billy B14 and ss+ arbs, LED's all inside & out with Dectane LED tailights. deflap, MRC Stage 2, Carbon Clean, no pre-cats, Custom Blueflame non res cat back exhaust, AP Racing Discs, alcantara wheel, gaiter and handbrake retrim, R8 gearknob, red belts (anyone want to swap belts for black ;-/ ) 438PS
eliano
Post by eliano » Tue Jun 06, 2017 9:52 pm
To note id also noticed a little belt whine from cold,shortly before this started
