For Milltek Owners
Iain
For Milltek Owners
Post by Iain » Fri May 19, 2017 7:20 pm
Guys
Quick one - for those with a millek does anyone else have this chirping sound, doesn't happen on boost, only when slowing down off throttle. sounds like waste gate chatter - but no boost for waste gate?
Might be normal as it sounds like a ticking sound on well, tick over too. :biggrin2:
https://youtu.be/rQBhrD7-K3E
Loving the exhaust was curious thats all.
Car runs A1, no smoke, no drop in performance. Car is epic
TIA guys. :bigwave:
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
E14STO
Re: For Milltek Owners
Post by E14STO » Fri May 19, 2017 11:12 pm
I'm sure mine doesn't.. but has downpipes so perhaps not an ideal comparison. I'll check tomorrow.
I think I also have some vids without the downpipes from JBS tuning site..
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
Tadass910
Post by Tadass910 » Fri May 19, 2017 11:57 pm
Guys
TIA guys. :bigwave:
I think it's normal, but you can ask also Miltek
RS6chris!
Post by RS6chris! » Sat May 20, 2017 10:52 am
Mine never did that
Non res cat back?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Iain
Post by Iain » Sat May 20, 2017 10:59 am
Non Res Cat back
Popped down to Kwik Fit to get it on the ramps - the chirping stems from the valves at the back as they are permanently open on mine.
It's booked in to Audi to get new valve plugs as they have corroded when I disconnected them - Typical!!
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
dasquade
Post by dasquade » Sat May 20, 2017 8:28 pm
Hmm, do you mind explain me what is wrong with the valves?
I mean, mine does exactly the same as yours...under load boots even raspier.
Tought it was normal :s.
What i do know is my valves work perfectly as i just installed a bypass module so i can manually open and close them.
So they do work and close properly.....or are they bit 'loose' when open and rattle?
https://www.dropbox.com/s/3oo15mhziv57z ... 9.mp4?dl=0
https://www.dropbox.com/s/q0n9iovf9jxmg ... 3.mp4?dl=0
*running an "extra ritch" backfire tune on prefacelift S6
Post by MikeFish » Sun May 21, 2017 12:30 am
Iain, when I unplugged my valves I plugged the loose cables into a set of Milltek valve delete modules. This keeps the connectors clean and stop dirt getting in and rusting. They also prevent the ECU throwing any errors (none show up on the dash but they do when you plug the car in for a download). Got £45 it was a no brainer.
http://www.venommotorsport.com/product/exhausts/EX1483/
Iain
Post by Iain » Sun May 21, 2017 8:47 am
Mike, thanks for this - thats where I fcuked up!! I didn't cover the connectors and they have corroded. It threw the error code up, but mine show up on the dash; also a faulty lambda sensor as of Thursday, which I'm hoping Audi won't say is a result of the Milltek!! - so its booked in to get the connectors replaced - £150.
@dasquade - I don't think theres anything wrong with the valves, its they just "chirp" as the gasses pass over them; weird thing is when accelerating there is no chirp and theres lots more gasses at a greater speed passing over them.
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
pez81
Post by pez81 » Tue May 23, 2017 10:56 am
Iain wrote:Non Res Cat back
Does it sound like a crow? My 2916 S6 did the same do disconnected the valves, problem solved. Garage said it's very common they had a 1 month old S1 had the same issue
Sent from my XT1580 using Tapatalk
pez81
*2016
Iain
Post by Iain » Wed May 24, 2017 8:43 am
Nope - too high pitched for a crow - having said that I have a theory - I disconnected the valves, it didn't happen; plugs corroded and I put them back in - valves seem to be working intermittently (hence the chattering perhaps) - am going to disconnect them again and see if the chattering disappears.
2009 R8 V10 Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
2003 996 DMS Turbo
wootner
Post by wootner » Sun Jul 16, 2017 1:52 pm
Mine makes that noise ....only when you let off the gas ...sound like a morris dancer / or castanets clattering
[url][/https://youtu.be/BEbul3jbGbcurl]
dasquade
Post by dasquade » Sun Jul 16, 2017 2:22 pm
The more non res millteks i hear the more i hear the typical rattling sound. Imho it is normal, at least with the valves open.
Going to catless dp's soon, wondering if that will change anything....
E14STO
Post by E14STO » Sun Jul 16, 2017 4:50 pm
Mine doesn't rattle.
DP's and 100 cell with non res
Current -
R8 V10 Plus
Previous -
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
Tadass910
Post by Tadass910 » Wed Jul 19, 2017 2:58 pm
Well going to cattles on non resonated Miltek may be a bad idea, as it will drone like hell in a highway, it drones now with stock dps so I can imagine how it will be with cattles dps, it will sound in comfort like now it's sounds in dynamic all the time.
