Diagnostic Help - Control Module/Databus/Voltage
ameet
Post by ameet » Tue May 09, 2017 11:19 pm
Hi guys,
Was driving along today and noticed the EPC light came on, did a few diagnostic scans, clear the codes, go for a drive etc, now the EPC light has gone and hasnt come back for a few hours of driving but I am still getting the below codes appear.
Just to give you some background to this a few weeks ago I was driving, car started to misfire and drive really badly, it turned out that one of the fuses under the ECU had blown, change that over and I changed the two relays under the ECU. One was for the ECM I believe (Both 614 relays). I haven't driven it much since then but it was working fine after changing the blown fuse and there were no error codes showing so not sure if this is related or not.
The Pre cats have been removed so an error code from Oxygen (Lambda) Sensor B1 or B2 S2 is expected. The sensor for the tyres is also there as the current wheels don't have the sensor.
Code: Select all
Address 01: Engine        Labels: 079-910-560-BNS1.lbl
   Part No SW: 8E1 910 560     HW: 8E1 907 560
   Component: 4.2L V8/4V FSI     ™0080
   Revision: --H13---    Serial number: XXXXXXXXXXXXXX
   Coding: 010C0003180F0160
   Shop #: WSC 00191 264 15243
   VCID: 63CFB3B7A240805994-8036
1 Fault Found:
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 151472 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 783 /min
                    Load: 15.3 %
                    Speed: 0.0 km/h
                    Temperature: 82.0∞C
                    Temperature: 39.0∞C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.589 V
Readiness: 0010 1001
Address 03: ABS Brakes        Labels: 8E0-910-517.clb
   Part No SW: 8E0 910 517 G    HW: 8E0 614 517 BD
   Component: ESP8 quattro    H06 0150
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0004533
   Shop #: WSC 06335 000 00000
   VCID: 2B5F1B978A1008196C-807E
No fault code found.
Address 08: Auto HVAC        Labels: 8E0-820-043.lbl
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   Shop #: WSC 00000
   VCID: 6DDBD58F2784C62932-5140
Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 10021
   Shop #: WSC 06335
   VCID: 3D7B25CF376496A9C2-4AEE
Address 11: Engine II        Labels: 079-910-560-BNS2.lbl
1 Fault Found:
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
               P0056 - 004 - Malfunction / Open Circuit - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 151472 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 769 /min
                    Load: 15.3 %
                    Speed: 0.0 km/h
                    Temperature: 82.0∞C
                    Temperature: 39.0∞C
                    Voltage: 13.589 V
Address 15: Airbags        Labels: 8E0-959-655-94.lbl
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G220S-
   Coding: 0430612
   VCID: 3B7F2BD77A709899FC-806E
   Subsystem 1 - Serial number: 6332DRB40370499ET
   Subsystem 2 - Serial number: 6342DRB40361D0B3L
   Subsystem 3 - Serial number: 6352ARB401629497K
   Subsystem 4 - Serial number: 6362ARB4016259F6R
   Subsystem 5 - Serial number: 63729RB40173E804K
   Subsystem 6 - Serial number: 63829RB40173E77D-
Address 16: Steering wheel        Labels: 8E0-953-549-T.lbl
   Part No: 8E0 953 549 T
   Component: Lenks·ulenmodul     0301
   Coding: 06022
   Shop #: WSC 06335
   VCID: 448D502B548EE7618D-4B08
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
   Part No SW: 8E0 920 981 R    HW: 8E0 920 981 R
   Component: KOMBI+WFS 4     H14 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0023411
   Shop #: WSC 36188 001 1048576
   VCID: 3C7D28CB7C7E9FA1F5-5122
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
   Coding: 0023411
   VCID: 3C7D28CB7C7E9FA1F5-5140
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760 A
   Component: Sitzverstellung H01 0020
   Coding: 00001
   Shop #: WSC 06335
   VCID: 326106F3FE3A59D12F-4B08
3 Faults Found:
53250 - Unknown Error Code
            Unknown - 04-10 -  - Intermittent
01317 - Control Module in Instrument Cluster (J285)
            49-10 - No Communications - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 K    HW: 8E0 035 192 K
   Component: RNS-E HIGH EU   H72 0650
   Revision:      01S    Serial number: AUZBZ7F1167151
   Coding: 0109153
   Shop #: WSC 02195 785 00200
   VCID: 2C5D188B8C1E0F2165-515C
1 Fault Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 132
                    Time Indication: 0
                    Date: 2005.08.26
                    Time: 01:14:48
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   Shop #: WSC 00000
   VCID: 6BDFDB971990C8192C-5106
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.clb
   Part No: 8E0 959 433 CH
   Component: Komfortger·t T3B    4135
   Coding: 07151
   Shop #: WSC 06335
   VCID: 79F3F1DF63CC6A89AE-4AEE
   Subsystem 1 - Part No: 8E2959802F
   Component: Tırsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tırsteuer.BF BRM 0606
   Subsystem 3 - Part No: 8E0959801E
   Component: Tırsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tırsteuer.HR BRM 0606
2 Faults Found:
00956 - Key 2
            35-10 -  -  - Intermittent
00532 - Supply Voltage B+
            37-10 - Faulty - Intermittent
Address 55: Headlight Range        Labels: 4F0-910-357.lbl
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Component: AFS 1           H01 0020
   Revision: 00000001    Serial number:
   Coding: 0000019
   VCID: 2953E19F80EC1A099E-807C
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H03 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH03 0010
1 Fault Found:
01314 - Engine Control Module
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 1
                    Time Indication: 0
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0109153
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 132
                    Time Indication: 0
                    Date: 2005.08.26
                    Time: 01:14:48
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0022523
   Shop #: WSC 02197 785 00200
   VCID: 2A511E9386EA111197-5140
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
            004 - No Signal/Communication - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 11
                    Time Indication: 0
             Freeze Frame:
                    (no units): 0.0
                    Voltage: 12.10 V
                    (no units): 33.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01521 - Sensor for Tire Pressure
            002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 11
                    Time Indication: 0
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802120618
   Coding: 0000114
   VCID: 326106F3AE3A59D12F-5140
2 Faults Found:
End-------------------------(Elapsed Time: 05:50)--------------------------
Users browsing this forum: No registered users and 93 guests
