Lowering a C7
RSVI
Lowering a C7
Post by RSVI » Thu May 04, 2017 12:15 pm
In a simple term, how do you lower the C7 like the below picture?
Rough cost and procedure?
Any real negatives?
TIA
Image Image Image
E14STO
Re: Lowering a C7
Post by E14STO » Thu May 04, 2017 12:21 pm
4 options as far as I can tell on a Dynamic car (shocks and springs)
H&r 20mm
H&r 40mm
KW adjustable springs
Air
I'd say this is air ride.
3k???
Handling - not sure, most say that on a decent road setting the air suspension is as compliant as other variants.
Never had it so can't comment from my perspective.
I think 40mm is a touch too low for me hence went with KW
Current -
R8 V10 Plus
Previous -
C7 RS6 Merlin, JBS stg3
997 Gen2 PDK Turbo
Nissan GTR (JM900R)
B7 RS4 TTS, Sepang, black optics, ceramics, miltek, cold air feed etc etc / leon Cupra
, B5 RS4(avus), 996 GT2, B5 RS4 (Misano), TVR Cerbera 4.5, Evo VII RS Sprint
Nissan GTI-R, Uno Turbo ie
almoRS
Re: Lowering a C7
Post by almoRS » Thu May 04, 2017 12:35 pm
I have H&R 20MM and does rub a bit when hitting a large dip at speed but handling is excellent. Springs only so not that expensive.
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Re: Lowering a C7
Post by MikeFish » Thu May 04, 2017 2:06 pm
That rs4 in the photo above is on air ride. You can do the same. Plush are daddies when it comes to air ride in my option and even more so when it comes to the RS6 as they own one too. And they can fit the adjustable height set up like that rs4 has and still keep the DRC! Not sure if anyone else offers that.
But I'm guessing you don't want air ride so springs or coilovers are your option. You can go really low like Jack Falla with coilovers and Rob. Or springs for a little less drastic drop.
Re: Lowering a C7
Post by MikeFish » Thu May 04, 2017 2:32 pm
All of the above is assuming you have DRC of course. If you have Audi air then it all changes.
Assuming DRC:
Cost for air ride is about 3k as stated above.
H&R springs are about £200 ish for springs and about the same to fit.
KW are somewhere in the 700s for springs and the same to fit as H&R
coilovers are about 2.5k I think for the super low kit.
RSVI
Re: Lowering a C7
Post by RSVI » Thu May 04, 2017 2:58 pm
Thank for your input guys!
My car has the air suspension, rather than the damper/spring setup (don't think it's got springs anyway??....)
Have I read somewhere on this forum about a 'widget' (a brace?) you can attach to the air suspension that lowers/adjusts ride height?
May have got the above wrong.
Like most things 'RS' related, anything you change isn't often a cheap change, but would be nice to know options for when I'm feeling flush ;-)
Image Image Image
Re: Lowering a C7
Post by MikeFish » Thu May 04, 2017 4:03 pm
Ah ignore all of the above then. Yes there is something like you suggested bit I can't recall the maker. Look for a thread about this previously. I know rtd was talking sbout it. If your car is pre facelift then it can be lowered using VCDS.
RS6chris!
Re: Lowering a C7
Post by RS6chris! » Thu May 04, 2017 4:07 pm
AlmoRS
What wheels are those?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
almoRS
Re: Lowering a C7
Post by almoRS » Thu May 04, 2017 4:17 pm
AlmoRS
BC Forged HS04's 21x10.5 :D
Previous:
Re: Lowering a C7
Post by MikeFish » Thu May 04, 2017 4:25 pm
You need more wheels Chris.
RSVI
Re: Lowering a C7
Post by RSVI » Thu May 04, 2017 4:31 pm
Thank you Mike, another good reason for sourcing a VCDS. Easy as 1-2-3?
almoRS- Nice motor!
Image Image Image
Re: Lowering a C7
Post by MikeFish » Thu May 04, 2017 4:37 pm
Lengthier than the normal VCDS change but it seemed fairly straight forward.
RS6chris!
Re: Lowering a C7
Post by RS6chris! » Thu May 04, 2017 4:59 pm
Deffo mate
Mods are under way
Trim getting wrapped next week
About to sort out booking on for Lowering
Just need to palm off these inspiris so I can purchase next wheels!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
RS6chris!
Re: Lowering a C7
Post by RS6chris! » Thu May 04, 2017 5:00 pm
AlmoRS
Link?
Cost?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Golfather
Re: Lowering a C7
Post by Golfather » Thu May 04, 2017 5:27 pm
Look similar to the VFS1's Chris
BTW this car is dropped on KW's
