Terrible radio signal
Jon_J
Post by Jon_J » Thu Apr 27, 2017 10:42 pm
I'm determined to get to the bottom of this. It's always been bad but has got worse since I installed LED DRL's. (I'll deal with that later) I have an A4 too and it's crap in that, I had an S4 before the RS and it was crap in that also.
So...has anyone fixed this. I've read hours of threads about a split in the rubber radio amplifier in the roof by the back window.
Mine had no splits but could still be faulty I guess.
Has anyone got a good signal and willing to let me try their part in mine before I shell out a couple of hundred to see if it fixes it?
Anyone got any suggestions to fix this?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
- Full Stereo install
S5 8T Cab White
A5 Cab 3.0 TDI Phantom Black
rickster147
Re: Terrible radio signal
Post by rickster147 » Fri Apr 28, 2017 7:20 am
Mines same since fitting drl
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
Jon_J
Post by Jon_J » Fri Apr 28, 2017 7:48 am
Strange. Like I said I deal with that later. Happy to remove them for now, fix this signal issue and then install them again to see what happens.
So anyone got a good radio signal or replaced their antenna?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Trups
Trader (Expired)
Post by Trups » Fri Apr 28, 2017 10:06 am
These mine guys?
Trups
Trups
Trader (Expired)
I know Ricksters are. need someone with my kit to try something.
Jon_J
Post by Jon_J » Fri Apr 28, 2017 10:11 am
Trups wrote:These mine guys?
Trups
Yes they are yours. Happy to help. I'm the one emailing you at the moment if you hadn't connected the two.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Trups
Trader (Expired)
Post by Trups » Fri Apr 28, 2017 10:31 am
I didn't lol.
Jon_J
Post by Jon_J » Fri Apr 28, 2017 10:35 am
Trups wrote:I didn't lol.
Ok. So happy to help once it's sorted.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
Starry
Post by Starry » Fri Apr 28, 2017 11:46 am
I hadn't connected the two, but mine is worse now then ever after fitting Turps's led's. I'll keep an eye on this thread...
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
rickster147
Post by rickster147 » Fri Apr 28, 2017 12:29 pm
Yes trups not all the time but if I pull up when it's crackling if I turn the drl off the quality is better then if turn on it goes back to bad again
I haven't fitted the beefed up cancellers yet BTW
The only time I get an error is when I start the car work the drl off
But 90 percent of the time drl is on when I start there car anyway so don't get any errors this way
Previous audi
Trups
Trader (Expired)
Post by Trups » Fri Apr 28, 2017 9:34 pm
The cancellers wont stop the radio interference, the cancellers are for the error system but as you say its only when your drls are off on start up which will sort that.
As this wasn't a report on Batch 1 I need to try a few things as when you go on sidelight mode I take it its back to normal?
I need the info so I can relay back to the factory but am trying a few things this week to see if it helps as the jist of it is that as standard it was fine but not great, with my DRL kit it wipes it out.?
Jon_J
Post by Jon_J » Fri Apr 28, 2017 10:00 pm
Trups wrote:The cancellers wont stop the radio interference, the cancellers are for the error system but as you say its only when your drls are off on start up which will sort that.
I'm happy to help with this. Let's get back to 'normal' and I'll work with you on this.
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
rickster147
Post by rickster147 » Sat Apr 29, 2017 8:53 am
It's same on drl and side light and full lights
Only good reception when all off
Previous audi
Jon_J
Post by Jon_J » Sun May 07, 2017 7:58 am
So we have established the signal is worse with the DRL on. I'd still like to get to a descent signal pre DRLs.
Does anyone have a good radio signal (FM) or does it keep loosing signal, if you click off that station and back again it is good for a bit and then goes back to being crackly?
RS4 B7 Sprint Blue
- Titanium Pack
- Black Optics
- B16's
- RNSE2 with AMI
- Reverse Camera
S5 8T Cab White
dougle_turbo
Post by dougle_turbo » Sun May 07, 2017 12:02 pm
My radio signal is good, happy to help if I can. Where are you located?
I've suffered from bad radio signal in various cars over the past and the culprit has always been something drawing power that wasn't installed on the car in the factory. i.e something plugged into a cig lighter, or an amplifier etc etc.
2010 987 Cayman S.
Clio 172 Cup track car "Nicole" aka NV2 Sold
Clio 172 Cup track car "Nicole" aka NV1 - R.I.P
2007 Phantom black RS4 avant - with added ceramics. Sold
2006 Phantom black RS4 saloon. Sold
1990 Black Audi S2 (3B) - full engine rebuild. Sold
1981 Black Porsche 924 Turbo, rescued from under a tree and restored. Sold
Users browsing this forum: Google Adsense [Bot] and 388 guests
