Oil leak
harding
Oil leak
Post by harding » Sun Apr 09, 2017 1:40 pm
Something is leaking from the forward right side of the car. Checked the oil cooler pipes from under the car and they looked in perfect condition. I talked to an audi mechanic aswell and since the oil is rather transparent/yellow-ish and not dark/black its probably not the oil cooler pipes.
What else is up there that might leak oil? :boohoo:
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
daytonamart
Re: Oil leak
Post by daytonamart » Sun Apr 09, 2017 1:51 pm
Aux rads?
Gone B7 RS4 Sprint Blue Avant
Gone B7 A4 Reflex Silver
Stew
Re: Oil leak
Post by Stew » Sun Apr 09, 2017 2:14 pm
I no this might not b for everyone but taste it if it if its a sweet taste its coolant if not it could be dog piss like what happened me a few years back :shock:
Grandadg90
Re: Oil leak
Post by Grandadg90 » Sun Apr 09, 2017 3:57 pm
Oil cooler pipes, looks block end.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
Audi Pardner
Re: Oil leak
Post by Audi Pardner » Wed Apr 12, 2017 7:51 pm
Could well be. Failed 'O' ring possibly.
Grandadg90
Re: Oil leak
Post by Grandadg90 » Wed Apr 12, 2017 10:52 pm
If it is, the o-rings are about £25 each from Audi. You will most likely need two. However you may have an issue with your actual pipes as sometimes they rub together which causes them to wear away at the braiding which causes them to split. There was a recall on these pipes due to this from Audi . However your oil drops seem to be minimal so I would lean towards the o-rings.
Hope that helps.
