Question about Engine sound setting
gtrs6
Post by gtrs6 » Fri Mar 31, 2017 9:10 pm
Working out if I have an issue with my exhaust - an RS6 Perf, in Individual drive select mode with Engine Sound set to Dynamic, when sitting at lights in gear and you flick back the gear stick to S mode, does the exhaust sound get noticeably louder or just the same as Individual/Engine Sound/Dynamic in D mode?
Pro
shanek
Re: Question about Engine sound setting
Post by shanek » Sat Apr 01, 2017 3:03 am
When you put the gear selector back into S mode, the sports exhaust valves should open and there should be a noticeable increase in exhaust noise regardless of engine sound setting, even at idle. The best way to tell though is during driving in S mode as when coming off the throttle and on down shifts, you should get some naughty noises coming from the exhaust!!
Post by MikeFish » Sat Apr 01, 2017 7:42 pm
Now, I have my valves disconnected to trying to remember back a year but this is my recollection:
If you are in dynamic the valves whould be open regardless of whether you are in D or S.
However, when you start the car in dynamic mode the car always starts in D with the vavles closed. If you pull the gear lever to put it into S then the vavles open but if you pull the lever again to go back inot D they will close again. Cycle through the Drive Select modes back round to Dynamic and the vavles should remain open regardless of D or S (until you turn the engine off and start it again). I imagine the same is true for Individual setting.
Give it a go and try.
However, the Sport exhaust is still so quiet even with the vavles open I don't know why you don't just disconnect the valves and leave them permanently open.
Iain
Post by Iain » Sun Apr 02, 2017 8:27 am
I did that on mine prior to me swapping it out with Milltek!! It will throw up a fault code, or rather it did with mine - engine management light will come on, relating to exhaust baffles!! just ignore the yellow light and enjoy the additional noise, though you WILL want a Milltek when you hear one...... :bigblink:
2018 Brabus G63 Widestar
2015 RS6 - with Added Milltek
2015 RRS - utter sh1te
2010 X5 4.0D M Sport
2009 R8 V10 Manual
2004 Lambo Gallarado Manual
3 x 997 C4S / C2s
2006 RS4 Avant
2001 RS4 - R500 FOR
1990 Dimma Cosworth H20 COS
2003 996 DMS Turbo
multiple 205's Dimmas
Post by MikeFish » Sun Apr 02, 2017 10:11 am
Mine didn't show a fault on the dash but it did show up when I plugged a laptop in. I bought the milltek valve delete modules for £45 And that cancels the errors.
Deleting the front and centre resonators for £360 gives a close to milltek sound.
Post by MikeFish » Sun Apr 02, 2017 10:12 am
skirs6
Post by skirs6 » Sun Apr 02, 2017 2:55 pm
I would agree with Mike with regard to sound for just over £300 it's a no brainer. I kept the valve option as it's quite nice to just cruise with the valves closed. Open in sport is LOL makes people jump when you lift off 👍👍
Y3CHR
Post by Y3CHR » Mon Apr 03, 2017 9:34 am
I followed Mike's advice and its by far and away a great mod for peanuts in comparison to the cost of a miltek etc.
Tadass910
Post by Tadass910 » Tue Apr 04, 2017 8:38 pm
In my experience if set exhaust in individual sections to dynamic you won't get bangs and pops when u drive with shifting paddles, if you choose dynamic in a main menu you get pops and bangs even not using shifts pads
Post by MikeFish » Tue Apr 04, 2017 8:57 pm
I get pops and bangs regardless of drive select mode. If gearbox is in S or M I get pops and bangs. If it is in D no pops and bangs.
The drive select mode changes the exhaust valves so makes it louder or quieter but doesn't affect the pops and bangs, only the gear box mode (yes I'm aware selecting Dynamic puts the gear box into S but if you pull the gear lever you go into D but are still in dynamic mode).
Eddie555
Post by Eddie555 » Tue Apr 04, 2017 9:10 pm
Yea that true Mike. But don't forget it works a lot better with a Miltek and ABT or MTM tuning box. :bigblink: :biggrin2:
Current ride’s
Previous rides
Post by MikeFish » Tue Apr 04, 2017 9:33 pm
LMFYAO (yeah it's almost yellow).
Eddie555
Post by Eddie555 » Tue Apr 04, 2017 10:06 pm
Almost? You mean you have <beep> stains after a Chicken Korma 😂😂😂
Current ride’s
Previous rides
Tadass910
Post by Tadass910 » Thu Apr 06, 2017 4:17 pm
Thanks for input
Users browsing this forum: No registered users and 111 guests
