WRS4
- 2nd Gear
Post
by WRS4 » Thu Mar 02, 2017 12:52 pm
So after alot of help on this site, ive decided to not waste money on a milltek ect, and go the straight pipe option / seal off vac pipes. So i have two questions that will then put this matter to rest.
1. are straight pipes something you buy ? and any advice where i can purchase these? OR is is a case of going to an exhaust center and just getting the muffler removed and get them to weld / fix the pipes straight through ? assuming they do this.
2. secondly i would like bigger bore tips tan the standard, are these removable / replaceable ? or can this only be dont with actually buying new rear exhausts with wider bores.
cheers all
Sprint Blue RS4 - 20" X 10J 3DSM Wheels - Carbon Front Splitter - Carbon Rear Diffuser - H & R Anti Roll Bars - Bilstein Adjustable Shocks - Milltek Exhaust System - De Catted - Valve Removed - MRC Stage 2 Re-Map - 480 bhp
pule333
- 5th Gear
Post
by pule333 » Thu Mar 02, 2017 1:10 pm
Hmmm. By straight pipes, you mean complete system replacing all silencers, cats and mufflers?? If that's the case lol I strongly advise you to rethink such venture, unless you really hate your neighbours or hard of hearing yourself... this will be loud. Nascar loud...
if you mean replacing Center pipe only? Than you can either buy them online or like you sad get an exhaust fabricators this task.
Rear tips aren't removable. But if you want to replace tips, they can be cut of and almost any other welded on.
Good luck! And if you do decide to go complete straigh pipe route lol please please come meet us on the 18th at Boxhill!
ilya, photographer
http://www.ikrylov.com
RS4 B7 aka Vinnie
rickster147
Post
by rickster147 » Thu Mar 02, 2017 1:14 pm
You can buy the pipes on eBay but it would be cheaper to just get a custom exhaust place to make some up for you as they have to cut the centre resonator out
If your wanting to be able to go back to a standard exhaust they can put sleeves on for you but this will be extra cost
Why would you want bigger tips it's the audi trademark
Rs4 b7 In avus silver with b14 Bilstein coilovers, centre resonator delete with x pipe and piggie cats gutted
Headlights detangoed trups led kit drl reverse and numberplate kit
Previous audi
rs6 c5 - mrc stage 2 remap-itg filters-forge dumpers-center decat with miltek kw coilovers- h and r
I call her the growler lol
marc1
Post
by marc1 » Thu Mar 02, 2017 1:21 pm
If you are happy to butcher the stock exhaust just take it t to any exhaust place and tell them to cut the centre resonator out and disconnect and plug the tail pipe flap vacuum hoses. Simples.
marc1
Post
If you are not happy to butcher the stock me. Buy mine cheap.
Post
by MikeFish » Thu Mar 02, 2017 1:27 pm
Which pipes can you buy? Are you talking about the Milltek non res centre section? Will this just fit into the OEM exhaust?
WRS4
- 2nd Gear
Post
by WRS4 » Thu Mar 02, 2017 1:27 pm
pule333 wrote: ↑Thu Mar 02, 2017 1:10 pm
yeah sorry i meant just the centre pipe lol, i know what you mean and cheers
WRS4
- 2nd Gear
Post
by WRS4 » Thu Mar 02, 2017 1:30 pm
marc1 wrote: ↑Thu Mar 02, 2017 1:21 pm
honestly if i cared about the original i would buy them, but not planning on getting rid of the car anyway so i am happy to butcher it lol.
do you have any other goodies for sale though
WRS4
- 2nd Gear
Post
by WRS4 » Thu Mar 02, 2017 1:31 pm
MikeFish wrote: ↑Thu Mar 02, 2017 1:27 pm
no i thought their were pipe sections you buy once the middle muffler is removed, but apparently i just get a garage to add pipe work in place of it.
IM LEARNING LOL
Post
by MikeFish » Thu Mar 02, 2017 1:35 pm
RS42017 wrote: ↑Thu Mar 02, 2017 1:31 pm
IM LEARNING LOL
That question was aimed at Ilya and Rickster as they both said you can buy them online.
rickster147
Post
by rickster147 » Thu Mar 02, 2017 1:42 pm
Yeah Mike you can buy the centre pipes on eBay they are miltek for 200 but not sure if they are bigger diameter to the stock ones
Previous audi
jonytek
- 5th Gear
Post
by jonytek » Thu Mar 02, 2017 1:48 pm
Just go straight through, ditch the back boxes!! There was a guy here that did it recently.... It lasted a day.
I really want to try get and someone to set my exhaust up so that the back boxes are removable and i can switch them for straight pipes. This would of course only be for shows etc.... Not sure it's feasible, it might be too much of a pain in the ass to switch over especially on the side of the road..
Mike do you think it would be any louder than that Tubi you used to have?
Post
by MikeFish » Thu Mar 02, 2017 2:19 pm
rickster147 wrote: ↑Thu Mar 02, 2017 1:42 pm
They are the right size but will they fit into the cut out section? I think the milltek runs a slightly different path to the OEM exhaust. Unless someone has tried this and can confirm it works I would avoid it. But if it does work then you could buy the Milltek H pipe which would join onto the front end of the centre section and then join onto the OEM downpipes / cats.
WRS4
- 2nd Gear
Post
by WRS4 » Thu Mar 02, 2017 2:21 pm
i think i will just go with a exhaust center mod, seems cheaper and easier and works just as well.
as always, all advice much appreciated
docurley
- 5th Gear
Post
by docurley » Thu Mar 02, 2017 3:17 pm
If you are going to all that trouble then get the piggies done at the same time and also think about have an X-Pipe done while your at it.
Users browsing this forum: Google [Bot] and 2141 guests
