Lowering and tyres
Floorit
Lowering and tyres
Post by Floorit » Sun Feb 12, 2017 12:12 am
Hi, needing new tyres and was thinking p zero's 275/30/21 in combination with mtm lowering springs front -40 mm and rear -45 mm, anyone done that ? Like to hear your opinion if you had any of those modifications.
2016 RS6 Performance
2016 RS6 MTM 722 all black (current)
2014 S350 22' CVT
2010 Golf 6R 20' rotor
2007 Clio RS F1
2006 E63 AMG
2005 RS6 C5
2002 GSX-R1000
1993 Golf 3 VR6
1992 ZXR 750 RR
1990 Golf 2 G60
1988 205 GTI 1.9
Re: Lowering and tyres
Post by MikeFish » Sun Feb 12, 2017 12:47 am
Why would you put such crap tyres on it?
Eddie555
Post by Eddie555 » Sun Feb 12, 2017 1:25 am
MikeFish wrote:Why would you put such crap tyres on it?
And the wrong size?
Current ride’s
Previous rides
RS6chris!
Post by RS6chris! » Sun Feb 12, 2017 8:09 am
Plenty of us running OEM size tyres, lowered and spacers with no issues.
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
Floorit
Post by Floorit » Sun Feb 12, 2017 11:19 am
And the wrong size?
Well, think it will look better because the tyre will be pulled more to the inside and will be a little less high and square on the wheel. And so far my experience is good with the pirelli's so if it doesn't influence the ride much think is the better option. Anyway, that's why I ask if anyone done it.
2014 S350 22' CVT
2007 Clio RS F1
2006 E63 AMG
2005 RS6 C5
2002 GSX-R1000
1993 Golf 3 VR6
1992 ZXR 750 RR
1990 Golf 2 G60
1988 205 GTI 1.9
Post by MikeFish » Sun Feb 12, 2017 12:05 pm
I get why you want to go a little narrower as I get a little rub at the front with 40mm springs. But won't they be slightly lower profile? And if you have the standard 21s then doesn't that increase the risk of buckling them?
Pirellis are the worst of the OEM tyres but if you are going a non standard size anyway then why wouldn't you put a decent tyre on?
Floorit
Post by Floorit » Sun Feb 12, 2017 12:17 pm
MikeFish wrote:I get why you want to go a little narrower as I get a little rub at the front with 40mm springs. But won't they be slightly lower profile? And if you have the standard 21s then doesn't that increase the risk of buckling them?
It would be slightly lower profile and the risk of buckling them is always there, has more to do how and where you drive, I do mostly highway so doesn't matter too much. Dunlop and Continental also offer 275/30/21 with R01 spec, you think one of those would be a better option ?
2014 S350 22' CVT
2007 Clio RS F1
2006 E63 AMG
2005 RS6 C5
2002 GSX-R1000
1993 Golf 3 VR6
1992 ZXR 750 RR
1990 Golf 2 G60
1988 205 GTI 1.9
Post by MikeFish » Sun Feb 12, 2017 12:31 pm
Michelin.
Edit not sure if Michelin are available in that size though.
Post by MikeFish » Sun Feb 12, 2017 12:32 pm
Not sure why you are bothered about R01 when using a non standard size tyre?
Floorit
Post by Floorit » Sun Feb 12, 2017 12:44 pm
MikeFish wrote:Not sure why you are bothered about R01 when using a non standard size tyre?
Dunno, it's Audi spec so wouldn't hurt. Anyway, they are all R01. Michelins are not available in that size as far as I can find. I read your thread, nice car you have I like the mods, did you try the spacers after lowering? Couln't find it so fast too much text. I have 20 mm each side, you know if they fit perhaps after lowering ?
2014 S350 22' CVT
2007 Clio RS F1
2006 E63 AMG
2005 RS6 C5
2002 GSX-R1000
1993 Golf 3 VR6
1992 ZXR 750 RR
1990 Golf 2 G60
1988 205 GTI 1.9
Post by MikeFish » Sun Feb 12, 2017 1:56 pm
My front tyres rub without spacers so would be silly to add any. I tried but there was no way it would drive like that. I have 15mm spacers on the rear.
Y3CHR
Post by Y3CHR » Wed Feb 15, 2017 1:52 pm
I have 20mm on the front Mike, only rubs occassionally on full lock, im going to look at this large mushroom like screw in the wheel arch as you suggested before and see how that goes.
Post by MikeFish » Wed Feb 15, 2017 2:14 pm
Yes get rid of that!
I am considering swapping to 20mm springs at the front to make it more level with the rear and add some spacers.
Currently have an error light for the suspension that won't go away. Says it is the right hand front level sensor but as it won't reset I'm guessing it has come unplugged or gone completely kapput is the wire has been broken. Just need time to get it up in the air and start pulling trim off to get to the sensor to check. I had nothing for nearly a year lowered then Chris asked me about an error last week and then it started happening!
RS6chris!
Post by RS6chris! » Wed Feb 15, 2017 5:54 pm
Had mine reset Mike
Hasn't come back in yet
Deffo seems to be level sensor....although my VAG man says fault was wiring related?
Always happens when fully loaded and Strangley when roads and car is filthy???....could just be coincidence?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
robf
Post by robf » Wed Feb 15, 2017 6:56 pm
Hi Mike, can you remove the mushroom screw with no affect then? That's good, as i had to raise my front slightly to get 15mm spacers on the front. I'm going to go down to around 5mm so i can get the front down again which i guess was about -60mm with no rubbing at all.
With 12mm spacers on the back mine was actually taking off tyre noticeably within a week of use; it was touching under load all the time. However, because the rear has camber adjusability, i have solved that by simply increasing camber.
Current Fleet:
2016 Audi RS6 Performance
2015 Porsche 991 GT3
2015 Porsche 991 Carrera 4 Cab
2012 Porsche Cayenne Diesel
2010 Land Rover Defender 5.0 V8
