Smoke on startup
O3mrt
Smoke on startup
Post by O3mrt » Sun Dec 18, 2016 12:28 am
I have spent hours of searching and still no definitive answer. Every cold start I get heaps of white smoke which is so rich in smell it can seriously burn your eyes.
The smell and smoke disappear within a minute. The car is garaged every night and sometimes not started until 2pm. So I believe that it cannot be condensation.
My old s3 had the same issue until I removed the SAI.
Has anyone had the same problem, removed the SAI and the problem disappeared?
Thanks,
Marty
pule333
Re: Smoke on startup
Post by pule333 » Sun Dec 18, 2016 12:35 am
Mine does the same. And I have removed SAI.
RS4 B7 aka Vinnie
O3mrt
Post by O3mrt » Sun Dec 18, 2016 6:21 am
pule333 wrote:Mine does the same. And I have removed SAI.
so removing the SAI and blocking the holes made no difference to the smoke issue?
Did it change anything at all?
Silverfox42
Post by Silverfox42 » Sun Dec 18, 2016 9:42 am
My B7 used to do this. I took it into Audi twice to investigate Plugs, the oil manifold and any fuel issues - nothing conclusive.
Speaking with other owners this behaviour is not unusual and something to do what the start up 'over run' which is designed to heat the Cats up quickly. Levels and colour of smoke vary by car and conditions.
I just lived with it and it seemed to get no worse over 4 years of ownership.
Previous:
jaysrs4
Post by jaysrs4 » Sun Dec 18, 2016 10:47 am
Try this - if you've been out in it (and it's obviously fully up to temperature). On the way home, like any good RS4 owner, give it a good bootfull a couple of times. I'm not saying drive it like you stole it, but a good couple trips up the rev counter. I've found it doesn't do it at all after this. If you trundle around in it and park it up, you'll find it'll do it. Not to mention, this'll contribute to carbon build up.
pule333
Post by pule333 » Sun Dec 18, 2016 11:09 am
To be honest with you, because I have no main cats, I figured this was the reason for smoking from cold anyways. Removing SAI did make it warm up slower. Sometimes I can drive for good 10min before oil up to 61deg...
RS4 B7 aka Vinnie
O3mrt
Post by O3mrt » Sun Dec 18, 2016 11:38 am
jaysrs4 wrote:Try this - if you've been out in it (and it's obviously fully up to temperature). On the way home, like any good RS4 owner, give it a good bootfull a couple of times. I'm not saying drive it like you stole it, but a good couple trips up the rev counter. I've found it doesn't do it at all after this. If you trundle around in it and park it up, you'll find it'll do it. Not to mention, this'll contribute to carbon build up.
I can definitely confirm that I don't get up when close to home, I'm still in the turbo frame of mind, drive off boost when close to turning the engine off.
I will give it a crack and report back.
pule333
Post by pule333 » Sun Dec 18, 2016 1:38 pm
Ha ha my wife said to me last week: "how do I know that you gonna be home in next 5 min? Are you Revving your car on purposefully?" Lol my reply was, "just doing some maintenance love" ha ha
RS4 B7 aka Vinnie
Covkiller
Post by Covkiller » Thu Dec 22, 2016 1:02 am
Mine used to do this, but I have no cats. MRC sorted it out on my last service. I'll look on my receipt and post the fix tomorrow.
Jules
Post by Jules » Thu Dec 22, 2016 9:55 am
Sorry but I'm so glad to read all this as mine does it also and I was starting to worry lol.
I also have no cats but I don't remember my last rs4 doing it.
I will try what Jay said also
Drive low,park lower
Post by MikeFish » Thu Dec 22, 2016 11:39 am
It's a known issue for cars with no pre cats. Mine started doing it the day I had my pre cats removed. I also had the SAI removed on the same day.
Covkiller
Post by Covkiller » Thu Dec 22, 2016 10:10 pm
MRC changed my Oil Separator and it stopped smoking. There always a little bit on start up, but no where near as before.
matt-jones
Post by matt-jones » Thu Dec 22, 2016 11:47 pm
Mine does it too but not massively, called MRC who said it's perfectly normal on a cold start, if it does it on hot starts then that's an issue.
O3mrt
Post by O3mrt » Sat Dec 24, 2016 1:02 am
Can 100% confirm that this works. Thank you sooooo much.
jaysrs4
Post by jaysrs4 » Sat Dec 24, 2016 9:50 am
Good stuff. It's a big old engine, it needs exercise ;)
Users browsing this forum: No registered users and 131 guests
