I'm looking for a front anti roll bar, 2003 B6 S4, are there any breakers about that can be recommended?
I've just had to change 2 front tires as the inner corners had lunched themselves, I had the drop links replaced by a garage in France who have managed to strip the threads in the end of one side of the sway bar and the drop link was not actually attached....
Any help is greatly appreciated!
Wanted - Any breakers out there - S4 B6 front ant roll bar
C6 S6 completely standard car just imported with full history from Switzerland - Needs an exhaust!!
B6 S4 Misano Red, KW V3's, RS4 ARB's, Miltek
Re: Wanted - Any breakers out there - S4 B6 front ant roll b
sorry miss posted, i have sway bars from my rs4 b7 kicking about if they are of any use..
Anti roll bar = sway bar (what the Americans normally call it!)
ARB's and sway bars are the same thing.
All A4 / S4 / RS4 front Anti roll bars are the same aross the B6 / B7 (8E0) platform. So you'll be best going for an A4 one as there will be more and will be sold cheaper. Personally though, the S4 needs tightening up massively, so I'd get the thick H&R RS4 bars front and rear and run both in their stiffest settings. I'd also disconnect the variable power steering relay to give it some much needed weight and stop it going light mid corner.
Thanks all,
I have the RS4 rear ARB which made a massive differednce to the handling
Unfortunately the front has stripped threads now in one end and is no longer bolted to the drop link.....
Mongo, I'll send you a PM.
