Miltek straight pipes
Howdy!
I bought my RS6 without the sport exhaust. Then i upgraded to a Miltek cat-back (None resonated) and it sounds amazing.
But i would like the sound i got when im flooring it all the time (Even at slow speeds) so im thinking about upgrading to straight pipes (Catalytic replacements)
Have anyone heard these and can give me their 5 cents?
Best regards
ras
http://www.stertman.se/avgassystem/3367 ... torer.html
Best regards
ras
Audi RS6 Misano build viewtopic.php?f=121&t=122026
Audi RS6 Misano & Audi R8 White Pictures https://postimg.org/gallery/19xrelsxq/
Re: Miltek straight pipes
Have you tried disconnecting the Milltek valves?
I know someone with the CAT delete and he says it's now too loud for him.
No i have not. But if they are disconnected. Dosent that mean that they are closed all the time?Andy_W wrote:Have you tried disconnecting the Milltek valves?
Disconnected means open all the time. Mine have been disconnected since week 1. Takes about 2 minutes to do and you don't even need to jack the car up, I did it lying on my back.
It does create an error code though ,but you will only see it if you plug a laptop into the car, no lights or errors on the dash. I have Milltek valve delete units that cancel the errors.
HI, just checking. With the plug unconnected, and valves open, it is only louder right but not as nice as putting the car into Dynamic mode right? thanks PhilMikeFish wrote:Disconnected means open all the time. Mine have been disconnected since week 1. Takes about 2 minutes to do and you don't even need to jack the car up, I did it lying on my back.
Mazda Eunos 800M, Mazda Tribute 3.0, Toyota Harrier 2.4, Lexus IS250 Deluxe, Audi Q7 3.6, Golf MKV R32, Audi MK2 TT 3.2, BMW X1 xDrive25i, Audi S5 Sportback, MB C63 Estate, Audi RS6
I have valved Milltek
So....if car setting for exhaust are in dynamic?...are valves not open all the time anyway??
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Not when the cruise control is on or reversing and a coupleRS6chris! wrote:I have valved Milltek
of other senarios that I can't remember.
I love driving mine in normal mode manual with valves open. Sounds great but without the constant popping.
I think when in dynamic the valves are open at idle then close just over idle to around somewhere around 3k rpm then open again in the first 3 gears and are open all the time in the other gears. That's how it work on other RSs so imagine the 6 is no different.
So disconnecting the valves makes it louder from idle to 3k in the lower gears. And makes it louder all the time in comfort.
MMmm
So if I pull the plug the valves will be open all the time?
Might have a play?
Might have a play?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
That's great Mike.
I start out with that and i see what i do from there
How do you disconnect this plugg? IS it under the rear muffler or?
And could you link me the unit you bought too delete the error code.
//Ras
//Ras
1). Engine module
Byte 9
Bit 2 - exhaust flaps installed (uncheck that)
Should be able to keep the flaps open permanently thrue VCDS.
Byte 9
MAgido here is a link to buy the miltek delete units. http://www.g-werke.com/exhaust-accessor ... dule-pair/
Current 2007 Black Rs4 B7,
Gone Bmw 118d, S4 b5, RS4 b5, A6 2.7t, passat cc, A4 1.8t, RS5 b5, 2012 A7, 2013 Phatom black RS6
Do these plug into wires From car to valves?
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
R8 V10 plus
C7 RS6
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW bora 150pd
Ford Focus zetec
Rover 214!!
Correct. Easy quick cheap mod! If you don't like it, plug them back in.RS6chris! wrote:MMmm
Might have a play?
Word of warning; I had trouble plugging them back in or plugging them into the delete units, I was messing around for ages trying to plug them in. A little squirt of fairy liquid and it took a few seconds.
Users browsing this forum: No registered users and 175 guests
