Audi rs4 b7 S button
Grizwold
Post by Grizwold » Wed Oct 12, 2016 7:29 pm
Hi guys the sport button on the steering wheel
Not sure it's working ??
I can't hear the obvious difference with it on
& the side bolsters don't inflate either when it's activated
Imm sure I've read that they do this .
Any help appreciated :?
Re: Audi rs4 b7 S button
Post by MikeFish » Wed Oct 12, 2016 7:40 pm
The bolster inflation can be deactivated on the DIS. Run through the menu to see if it is on or not.
Does the green S light come on the dash when you press the button?
Grizwold
Post by Grizwold » Wed Oct 12, 2016 8:11 pm
Yeah green light comes on in dash mike , imm led to believe the flaps open at
Certain revs ?
Where & what are the settings on dash to enable seat
Bolsters thx
It's no biggie but I like things to work as they should :thumbs:
Post by MikeFish » Wed Oct 12, 2016 8:19 pm
Yes regarding flaps. But they might have been disconnected to make the exhaust sounds better. Take a look in the exhaust pipes. You should see the flaps in one of the 2 pipes that feeds each oval. When the engine is off the flap should be open. Start the car and they should close, press the sport button and they should open (at normal idle not fast idle).
There are a load of options and settings in the DIS like setting tyre pressures, unit if measurement etc. It's been a while but I think it's the buttons on the steering wheel you use.
Grizwold
Post by Grizwold » Wed Oct 12, 2016 8:24 pm
Brill thanks for that I'll try tomoz after work ,
If can't sort maybe yourself or a member could have a butchers
Saturday at Combe :thumbs:
Users browsing this forum: No registered users and 100 guests
