Battery question
CaptainLeadFoot
Battery question
Post by CaptainLeadFoot » Tue Oct 04, 2016 5:27 pm
Hi all,
It's time to replace the car's battery and I want to change to the AGM type.
Just wondering if anyone is using that and if you need to VCDS re-code the car to learn the new battery ? What brand and model would you recommend ?
Re: Battery question
Post by MikeFish » Tue Oct 04, 2016 6:08 pm
No issue with changing battery.
I have a Banner AGM one because when I changed it I still had my big car stereo in and the Banner batteries are very good for this type of thing.
CaptainLeadFoot
Post by CaptainLeadFoot » Tue Oct 04, 2016 6:25 pm
Cool ! Are you using the AGM 605 01 ? do you know what is the size the battery compartment can fit ?
I'm thinking of the Varta AGM, but it looks to be rather big and at 29kg it's not light:
http://www.varta-automotive.com/en-gb/p ... 05-901-095
Comparing to the non-AGM one that I am using:
http://www.varta-automotive.com/en-gb/p ... 10-402-092
The site suggested for a lower capacity and cold cracking amp...I wonder if that is sufficient to start ?
http://www.varta-automotive.com/en-gb/p ... 95-901-085
Post by MikeFish » Tue Oct 04, 2016 6:42 pm
I think the B7 uses the 020 size. Can't remember the dimensions though.
irishmike
Post by irishmike » Sun Oct 09, 2016 4:23 pm
You'll have to recode the remote central locking and one touch windows, that's about it and are easily done.
The size is 020, Bosch specs below
Amp Hours (Ah): 110AhCold Cracking Amp (CCA): 920CCALength: 393mmWidth: 175mmHeight: 190mm
One thing is the cranking amps, I wouldn't go lower. I had an issue with a battery that was just below full capacity and had issues starting. I needed to turn off auto lights and anything else to get it started.
CaptainLeadFoot
Post by CaptainLeadFoot » Mon Oct 10, 2016 5:42 am
Thanks. Is it ok if the Amp Hours is a bit less ? From what is available here in Hong Kong, the AMGs available are either 105 or 95 Ah. Otherwise I have to go back to the traditional ones for 110Ah.
Users browsing this forum: No registered users and 182 guests
