Dear all,
Recently I fitted an oil catch can on my 2010 Audi TT RS.
Just wanted to share this for anyone interested in also putting a catch can in their car.
[IMG]httpwww.audi-sport.netxfdataattachments6969118-388fc9f4e6a3c89b2f8a981f76895935.jpg[IMG]
This is the Mishimoto Compact baffled oil catch can (bought on e-Bay).
[IMG]httpwww.audi-sport.netxfattachmentsmishimoto-compact-baffled-oil-catch-can-2-port-29-jpg.82984[IMG]
Here you can see all the parts and the brass filter which separates the oil and air, the baffles and the bottom plate which will keep the oil inside the can.
[IMG]httpwww.audi-sport.netxfdataattachments6969119-9ffe401ff340bfa153f7dd5212fb4466.jpg[IMG]
This is the hose of the front cam cover.
[IMG]httpwww.audi-sport.netxfdataattachments6969120-f1f3ab9074d38f0472dfa5fadd7be1ad.jpg[IMG]
After heating that tube a little bit the connectors can be pulled out (this tube costs €275,- from the dealer!).
[IMG]httpwww.audi-sport.netxfdataattachments6969121-7393abc083ff4bf998bf33e3c2e25359.jpg[IMG]
This is the heat isolated hose going towards the turbo which will be modified.
[IMG]httpwww.audi-sport.netxfdataattachments6969122-1ef95c6742f73dcb84b5da9571dc7a88.jpg[IMG]
After loosening two Torx 30 this will come off.
[IMG]httpwww.audi-sport.netxfdataattachments6969124-1ffa0c21d9d144786ad86dadfef01c1d.jpg[IMG]
Here the heat isolation is stripped down a bit to heat that connector too, it will also come off with heat
[IMG]httpwww.audi-sport.netxfdataattachments6969123-942152644c305de9950dc454035d7d03.jpg[IMG]
Here you see that connector (21mm outer diameter).
[IMG]httpwww.audi-sport.netxfdataattachments6969125-5bc2df27f84f3aab8caf5c5ef0d0bf5a.jpg[IMG]
This is the catch can with the drain hose attached to it including a little valve. The bigger hose is the one that also is needed to fit the catch can.
[IMG]httpwww.audi-sport.netxfdataattachments6969126-ca90a2124a3c1d1f4c51f4de4778ce31.jpg[IMG]
The valve
[IMG]httpwww.audi-sport.netxfdataattachments6969127-f55480b5e752b5c26e00db153639a79f.jpg[IMG]
Overview of the situation.
[IMG]httpwww.audi-sport.netxfdataattachments6969128-e503975f41b2441ed4c94d64cad4a0ac.jpg[IMG]
Close-up of the oil and gasoline resistant hose (21mm inner diameter)
[IMG]httpwww.audi-sport.netxfdataattachments6969130-e81ca71beab2a0932e3ba48cc46f0aba.jpg[IMG]
This is to show you where this hose will be placed.
[IMG]httpwww.audi-sport.netxfdataattachments6969131-83226bad247869cbda2ebc63fde8d7f1.jpg[IMG]
Heat isolation is needed because of the turbo.
[IMG]httpwww.audi-sport.netxfdataattachments6969132-31c66b2a52f2dc89003b738f4778d541.jpg[IMG]
Here you can see two screws where the catch can will be attached to with a bracket.
[IMG]httpwww.audi-sport.netxfdataattachments6969133-613c80454818fa821c6e08b42afac675.jpg[IMG]
Bracket installed
[IMG]httpwww.audi-sport.netxfdataattachments6969134-1825e72b6c8b7e179dcdc20dd4c1af08.jpg[IMG]
Catch can with drain hose
[IMG]httpwww.audi-sport.netxfdataattachments6969135-d018af72fe6dc1cfe1a4abd106ca4290.jpg[IMG]
Catch can installed
[IMG]httpwww.audi-sport.netxfdataattachments6969136-095e3932e8a907be9f86336fc4f40a1b.jpg[IMG]
Overview
[IMG]httpwww.audi-sport.netxfdataattachments6969137-9033fdacd9b80ba821366843531d57b3.jpg[IMG]
Drain possibilty because of valve underneath the car.
[IMG]httpwww.audi-sport.netxfdataattachments6969138-6d7c7e65bfba6d15ced6500351876f39.jpg[IMG]
By using the original connectors a hose was attached (oil and gasoline resistant) with a plug inserted.
[IMG]httpwww.audi-sport.netxfdataattachments6969145-f370c54a400330cea03d5011bdeb4577.jpg[IMG]
Another close-up after covering up the brass connectors with some black tape.
[IMG]httpwww.audi-sport.netxfdataattachments6969146-ac5b1fd98d7010a33c0cb5bf850bd8b8.jpg[IMG]
Another close-up.
I hope you enjoyed the write up, if you have any comments or questions just ask.
Mark.
Oil catch can for Audi TTRS 2.5 TFSI
Jump to
- General Discussion Forums
- ↳ Welcome Area
- ↳ General Car Chat
- ↳ Trackdays and Meets
- ↳ Spotters Forum
- ↳ Adversaries
- ↳ BMW M & Alpina
- ↳ Jaguar R
- ↳ Mercedes-AMG
- ↳ Nissan GT-R
- ↳ Opel VXR & HSV
- ↳ McLaren
- ↳ Porsche
- ↳ Volvo S60 Polestar
- ↳ Other
- ↳ Audi S and RS Ownership
- ↳ DTC / VCDS
- ↳ Electrical
- ↳ Cleaning & Car Care
- ↳ Readers' Rides
- ↳ Off Topic Chat
- ↳ Cars
- ↳ Parts
- ↳ Group Buys
- ↳ Other
- ↳ Ads Up To End Of 2010
- ↳ RS2 (B4) 1994-1995
- ↳ RS3 (8PA) 2011-2012
- ↳ RS3 (8VA) 2015-
- ↳ TTRS (Mk3 Typ 8S) 2014–
- ↳ RS4 (B5 Typ 8D) 1999-2001
- ↳ RS4 (B7 Typ 8E) 2006–2008
- ↳ RS4 (B8 Typ 8K) 2012-2016
- ↳ RS4 (B9 Typ 8W) 2017-
- ↳ RS5 (8T) 2010–2015
- ↳ RS5 (F5) 2016–
- ↳ RS6 (C7 Typ 4G) 2013-2018
- ↳ RS6 (C8 Typ 5G) 2019-
- ↳ RS7 (4G) 2013-2019
- ↳ RS7 (C8) 2019-
- ↳ RS Q3 (Typ 8U) 2013-
- ↳ RS e-tron GT (J1) 2020-
- Audi S Discussion Forums
- ↳ S Forums (Up to 1997)
- ↳ S1
- ↳ S2
- ↳ S4 2.2 / S4 4.2
- ↳ S6 / S6 Plus
- ↳ S1 (Typ 8X) 2014-
- ↳ S3 (Typ 8L) 1999-2003
- ↳ S3 (Typ 8P) 2006-2012
- ↳ S3 (Typ 8V) 2013-
- ↳ TTS (Typ 8J) 2008-2014
- ↳ TTS (Typ 8S) 2014-
- ↳ S4 (B5 Typ 8D) 1997-2002
- ↳ S4 (B8 Typ 8K) 2009-2016
- ↳ S4 (B9 Typ 9L) 2017-
- ↳ S5 (B9) 2017-
- ↳ S6 (C5 Typ 4B) 1999-2003
- ↳ S6 (C6 Typ 4F) 2006-2011
- ↳ S6 (C7 Typ 4G) 2012-2018
- ↳ S6 (C8) 2019-
- ↳ S7 (Typ 4G) 2012-2017
- ↳ S8 (D2 Typ 4D) 1992-2002
- ↳ S8 (D3 Typ 4E) 2002-2009
- ↳ S8 (D4 Typ 4H) 2010-
- ↳ SQ2 (MQB) 2019-
- ↳ SQ5 (Typ 8R) 2013-2017
- ↳ SQ5 (Typ FY) 2017-
- ↳ SQ7 (Typ 4M) 2016-
- ↳ SQ8 (MLB) 2019-
- ↳ Circuit Days
- ↳ Destination Nurburgring
- ↳ EM Tuning Products
