can someone help me identify the PCV crank case breather on the 2.0 TFSI engine apologies this isn't RS related
my friends car and when I open the oil cap the engine is in vacuum so ross tech suggests that the crank case breather is fooked
2.0 TFSI B7
boombastik
2.0 TFSI B7
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
Re: 2.0 TFSI B7
Do you see that ally metal plate with two black pipes? That's where the OEM pcv valve is.
By the way this kit I have is for sale if you friend wants to eliminate this problem once and for all
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
boombastik
Re: 2.0 TFSI B7
Re: 2.0 TFSI B7
Yes
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
boombastik
Re: 2.0 TFSI B7
perfect cheers
Re: 2.0 TFSI B7
I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
boombastik
Re: 2.0 TFSI B7
Don't think she's that bothered as long as it fixes the issue.TobyRS4 wrote:I'd recommend the external oil catch tank type like pictured, had the same issue on a mk5 golf gti 2.0 tfsi and fitted a catch tank as above which cured the problem
Re: 2.0 TFSI B7
Like I said, pm me if interested.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
