SOLD - RS6 C5 Avant - Misano Red - New Brakes & Tyres
ChrisRS
Post by ChrisRS » Mon May 23, 2016 8:54 pm
Hi all,
Here for sale is my beloved and very well looked after 2003 Audi RS6 Avant.
I am looking for £11,495 or a very near offer.
The only reason for sale is that I am now facing the reality that I need to raise some cash for a mortgage deposit and require a car that's cheaper to run.
The car is in fantastic condition - inside and out.
Drives and stops brilliantly - has just been serviced and had new front brakes and tyres all round (see below)
The car is stored at my home address in South Manchester - close to the Trafford Centre.
I purchased the car at the end of January from a fellow forum user, that post can be seen here;
viewtopic.php?f=63&t=118647&p=777864&hi ... an#p777864
I drove the car for 3 months as a second car and put just over 4K miles on her in that time and have been driving daily since start of June.
Mileage is now just over 92K and rising slightly.
Although I do not have access to a garage for storage - the car has been kept in an brand new size 4 outdoor CarCoon when not being used, which is available for sale at an additional cost - it was £500 new.
The car has always been hand washed and waxed by myself meticulously.
The car is on an 03 plate and was first registered on 12 May 2003
It has MOT until 31st of October 2016.
There have been 7 previous owners to myself, with the previous owner to me keeping and cherishing the car for 6 years - ChrisRS6
I have the full V5 registered in my name and address, a folder full of history (below), the original Audi manuals, folder and service book and 2 working keys.
I have a folder full of receipts and service history on the vehicle, which I have gone through and detailed into a list, see below;
12th May 2003 – Delivery to Customer by Dundee Audi, DD1 5RJ
13th May 2004 – 10,543 Miles – Dundee Audi, DD1 5RJ – Oil Change & Inspection
23rd January 2006 – 20,035 Miles – David Underwood – Major Inspection, Oil & Brake Fluid
28th January 2007 – 30,609 Miles – David Underwood – Oil Change & Inspection
11th December 2008 – 38,672 Miles – David Underwood – Oil Change & Inspection
5th May 2009 – 43,608 Miles – Swifts DU Performance, S1 4JR - £1551.50 – the following;
• Cam belt with tensioners and rollers
• Water pump
• Aux drive belt
• Thermostat
• 5W40 Oil
• Oil Filter
• 8 Spark Plugs
• Pollen Filter
• Sump Plug Seal
• Fuel Filter
• 2 Conti Sport Con 3 255/35/19 96Y
24th July 2009 – Whetstone Audi, N20 0PT – £64.98 - Front Wiper Blades
29th September 2009 – Unit 20 - £2457.99 – the following;
• H&R’s fitted
• Rear discs & pads
• Aero wipers
• Rear wiper kit
• Gearbox service with filter
6th April 2010 – 47,360 Miles – Wheels In Motion, HP5 1SD – £141 - 4 Wheel Alignment
20th May 2010 – 47,629 Miles – Russell Automotive Centre, NW9 8AU – LongLife Service
9th September 2010 – Uplands Car Radios, BS6 5RE - £180 – iPod 20 Pin connector fitted
31st October 2010 – Kwik Fit, BS6 5RE - £987.60 – 4 MI255/35Y19PS3X & Wheel Balance
5th November 2010 – Mobile Windscreens, BS2 0HL – Windscreen Chip Repair
5th July 2011 – 54,267 Miles – Bristol Audi, BS10 7FF – £282.42 Oil Change & Inspection
6th July 2012 – 60,822 Miles – MRC Tuning, OX16 4RZ – £1874.89 – the following;
• 5W40 Fully Synthetic Oil
• Oil Filter
• 8 Spark Plugs
• Air Filters
• Pollen Filter
• Brake Fluid
• 2 Front Discs
• Front Brake Pads
• Outer CV Boot
21st July 2012 – Go Cool Services, BS36 2PL - £185 – Replace AC pressure switch and gas
23rd March 2013 – 64,508 Miles – Bristol Audi, BS10 7FF - £700 – the following;
• Gearbox oil leak resolved by replacing O ring & gasket
• Replaced OSF door lock mechanism
2nd August 2013 – 67,075 Miles – Newbury Audi, RG14 2AB – £1480.02 – the following;
• Castrol Edge Pro Longlife 5W30
• Oil Filter
• Sump Plug
• 8 Spark Plugs
• Cambelt with tensioners and rollers
• Water Pump
• Thermostat
• Rear Wiper Blader
• Interior Bulb
27th September 2013 – FCM Wheel Alignment, BS5 9PQ - £70 – Four Wheel Alignment
27th September 2013 – 67,895 Miles – National Tyres, BS5 5QH – 2 Bridgestone RE05OA 96Y XL - REARS
26th May 2014 – 73,296 Miles – Bristol Audi, BS10 7FF – Oil Change & Inspection
9th June 2014 – MyAlloys, RG24 8QU – £746.40 - Refurbish wheels and supply 2x Bridgestone RE05OA 255/35R19 96Y XL - FRONTS??
14th June 2014 – 72,604 Miles – Protyre Bristol, BS5 9JJ – £30 - Front Wheel Alignment
28th June 2014 – 73,296 Miles – Bristol Audi, BS10 7FF - £732.62 – the following;
• Replaced alarm button
• Replacement NSF inner & outer CV boots
• Audi variable service – oil & filter change
8th July 2014 – 73,423 Miles – Newbury Audi, RG14 2AB - £583.91 – the following;
• Removed and replaced rear flange and propshaft oil seal
• Cleaned off excessive oil from heat shields
• Cut off exhaust sleeves as corroded
• Replaced anti roll bar buses
24th September 2014 – 75,088 Miles – Newbury Audi, RG14 2AB - £67.40 – the following;
• Removed & cleaned NSR brake caliper assembly – advised rebuild or replacement
16th December 2014 – 77,254 Miles – Newbury Audi, RG14 2AB - £1463.92 – the following;
• Rear brake discs & pads including NSR brake caliper re-assemble due to sticking
• Brake fluid change
• Replaced leaking nearside front driveshaft oil seal
29th June 2015 – 81,568 Miles – Newbury Audi, RG14 2AB – £795.04 - LongLife Service including;
• Castrol Edge Professional 5W30 longlife oil
• Reset service light
• Oil Filter
• Pollen Filter
• Fuel Filter
• Air Filter
• Sump Plug & Washer
• Rear Bridgestone 255/35 R19 96Y tyres
• Aerial Mast
• Cleaned rear washer jet
19th November 2015 – 85,357 Miles – V Hub Service Ltd, GL20 8SR – “Bufkin” Coolant pipe, coolant & oil filter replacement - £600
4th July 2016 - 90,810 miles - Manchester Audi - Brand new front discs & pads, interim service and full health check - £1480
19th July 2016 - 91,200 miles - National Tyres Altrincham - 4 Brand new Michelin Pilot Super Sports 255 35 R19 96Y - £700
The only modifications that have been done to the car from stock, to my knowledge, are;
Replacement GPS receiver that sits in the passenger corner of the dashboard, as the factory one is apparently no longer accurate.
DRC suspension removed and replaced with H&R coilovers - I do have adjusting spanners for these.
Dension 20 pin iPod connector in glovebox
Further pictures can be viewed here; http://s1360.photobucket.com/user/chris ... ibrary/RS6
Please let me know if I have missed anything out or if you're interested!
Chris
Current; C5 RS6 Avant - For Sale
Gone; 1.6 MK4 Golf, '85 Daimler Double Six, E46 325Ci Sport, 159 1.9 JTDm, W211 E320 CDI Avantgarde
ChrisRS
Re: For Sale - RS6 C5 Avant - Misano Red
Post by ChrisRS » Mon May 30, 2016 3:52 pm
Hi all,
The RS6 has now just clocked over 90K miles and shall be used daily for now, only doing approx. 10 miles per day due to my new job.
If it has not been purchased by the end of June, I shall get an interim service done, have the front brakes sorted and a full health check; all done by Audi Manchester.
I would be happy to take no less than £10K prior to this work being done.
Cheers,
Chris
koblih22
Re: For Sale - RS6 C5 Avant - Misano Red - 90K - FSH - £10,2
Post by koblih22 » Mon May 30, 2016 8:20 pm
One of the nicest RS6 Ive even seen, even just on the pictures. Looks amazing and sounds like a well sorted example. If only the VRT and insurance robbery in ROI wouldnt be present of I would find a way how to get this gem.
Best of luck with the sale!
Rob
ChrisRS6
Post by ChrisRS6 » Thu Jun 02, 2016 11:32 am
Good to see some pics of the old-girl.. still looking good!
*SOLD* - currently looking for a replacement
03 Missano Red Avant
Silver Leather, H&Rs, Dension iPod Connection kit
85k miles
ChrisRS
Post by ChrisRS » Thu Jun 02, 2016 7:16 pm
She's doing well thanks Chris! Just started a new job, so I might even be able to keep her!! Do fancy a go in an RS4 or an RS3 though :bigblink:
Have you found a replacement beast yet?
ChrisRS
Re: For Sale - RS6 C5 Avant - Misano Red - 90K - FSH - £10,0
Post by ChrisRS » Sun Jun 12, 2016 1:32 pm
Hi all,
Now reduced to £10,000 or very near offer.
If not sold by the end of June, she will get brand new front brake pads and a interim service as at Audi and then price will rise accordingly.
Cheers,
Chris
SuprSi
Post by SuprSi » Sun Jun 12, 2016 8:33 pm
Hi Chris,
I may possibly be interested in the Carcoon if the next owner doesn't want it. Provided the price is reasonable. Give me a shout if you need to shift it :) Good luck with the sale of the '6 too.
ChrisRS
Post by ChrisRS » Sat Jun 18, 2016 9:50 am
Hi all,
The RS6 is now booked in for its interim service and new front discs and pads with Audi Manchester on 1st of July.
Once this has been done, I will be asking £11,000 or very near offer.
Mileage is currently 90,450 and rising slowly.
Cheers,
Chris
ChrisRS
Post by ChrisRS » Mon Jul 04, 2016 7:55 pm
The RS has now had new front discs, pads and an interim service at Manchester Audi at a cost of £1480!!
Tyres are at 5mm on the front and 4mm at the rear.
Full health check carried out by Manchester Audi, with nothing found wrong - no leaks or gremlins!
Mileage is currently 90,840 and rising.
Price is now £11,000 or very near offer.
Chris
neilaudirs6
Re: RS6 C5 Avant - Misano Red - 91K - FSH - New Brakes - £11
Post by neilaudirs6 » Fri Jul 08, 2016 7:30 pm
hi is this still for sale?
ChrisRS
Post by ChrisRS » Fri Jul 08, 2016 8:47 pm
Hi Neil,
Yes, the RS is still available for sale.
Let me know if you would like any further info.
Chris
ChrisRS
Post by ChrisRS » Tue Jul 12, 2016 12:49 pm
Hi all,
Unfortunately, I got a puncture on a rear tyre and have managed to knacker the sidewall on it :bash:
But, it has now been booked in to have 4x brand new Michelin Pilot Super Sport tyres fitted on Tuesday 19th July, with 4 wheel tracking of course - at a cost of £750.
So it has now been serviced, had the front brakes replaced and shall now have 4 brand new tyres with alignment.
If wanted, the car will also come with the 3x remaining Bridgestone RE050A tyres - 2 from the front with 4mm and 1 from the rear with 5mm.
Everything sorted and ready to go to the new owner.
As said previously, I am in no rush to sell and shall continue to drive the car until a sale is agreed.
Chris
Re: RS6 C5 Avant - Misano Red - 91K - FSH - New Brakes & Tyr
Post by chunky79 » Fri Jul 15, 2016 8:01 pm
Good move in getting all new tyres, and good ones at that.
Good luck with the sale.
ChrisRS
Post by ChrisRS » Wed Jul 27, 2016 12:27 pm
Thanks chunky79 :beerchug:
Quick update all;
Got the 4 new Michel Pilot Super Sports fitted on Monday 25th July and my opinion; WOW! The increase in grip and confidence given when going round corners at speed is night and day, when compared to the previous Bridgestone Potenzas.
I have also treated all of the exterior black plastic trim to a clean and coating of GTechniq C4 permanent trim restorer; this has given them a much better look from the slightly faded grey that they were, without having to re-spray/replace them. This is supposed to last over a year, according to online user reviews.
I have now also got GTechniq C5 on order, which also has good reviews, which is to be used to seal the wheels and make it a lot easier to remove brake dust and other dirt.
At some point, I shall probably make another thread with comparison pictures and the detailing that I have done/regularly carry out.
Chris
northern8019
Post by northern8019 » Fri Jul 29, 2016 9:32 am
Chris
Anything in service history regarding gearbox servicing or issues?
Regards
Users browsing this forum: HPsauce and 87 guests
