high miles c6?
5.0 V10 50v biturbo - 571 bhp
discostu49
high miles c6?
Post by discostu49 » Sat May 21, 2016 9:13 pm
hi guys I've been looking at the next car and it was a choice between a porsche cayenne its 2009 plate or a c6 rs6 avant
thankfully i have went with the audi
so the lookout/seach goes on
unfortunately my budget caps at 25k
so for that I'm looking for a red/blue or black car with sunroof.
was looking at getting something between the 60-70k miles as i only do about 5k a year and looking to keep this for a good few years
however I've been on auto trader and such sites and unfortunately seem to be able to see cars with over 80k for my budget. :cry:
is there known faults with the c6? e.g. what to look out for?
what should be done around the 80k mark? e.g. chains,pumps,belts??
rs6_sid
Re: high miles c6?
Post by rs6_sid » Sun May 22, 2016 12:24 am
To be honest i have one thats done 84k its had everyrhing done runs like a dream , audi did the oil pump seal and lots of other bits about 10k ago if its had the oil pump sorted your on to a winner
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
Shinobi675
Re: high miles c6?
Post by Shinobi675 » Mon May 23, 2016 12:31 am
Having the seals and coolant pipe go on mine recently, id say check its already had the engine out and when out all the seals were replaced. That's about it really.
Where abouts are you?
R33
Re: high miles c6?
Post by R33 » Mon May 23, 2016 10:50 am
Shinobi675 wrote:Having the seals and coolant pipe go on mine recently, id say check its already had the engine out and when out all the seals were replaced. That's about it really.
Same here, but other than that I'm getting on for 90K now with no issues.
IanH755
Re: high miles c6?
Post by IanH755 » Mon May 23, 2016 11:07 am
The issues currently are more "Age" related than "Mileage" related so after 6-8 years rubber seals are starting to perish and pipes are starting to corrode. As for "mileage" issues I can't think of any except maybe the clicking wheel bearings, which seems to be pretty much non-existent now.
As for 80k miles servicing - Audi has two types of service, a 10k mile "minor" and a 20k mile "major", so at 80k miles I'd expect it to either need or just had a major servicing (around £700 from a specialist or £1200+ from Audi) which includes the spark plugs. Outside of what Audi say about the gearbox (sealed for life) I'd also get that serviced too (oil & filter for£450).
Hope that helps.
TomRS
Re: high miles c6?
Post by TomRS » Tue Jun 07, 2016 10:47 am
Pretty much what Ian said,
Im coming up 82k soon and mines been spot on, i've had the box oil and filter changed, i'll be servicing it and doing the plugs this Saturday ready for le-mans trip next week.
I do need to take it to Audi or find someone that can "electronically" stamp it for me as i do most of the work myself havent had this one a year yet (november) so i dont need to worry about the servicing book just yet but i do need to find a way to get it stamped, i really dont want to be paying Audi big money.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
bhprs4
Re: high miles c6?
Post by bhprs4 » Fri Jul 29, 2016 2:19 am
Is there any specific brand or grade of oil recommended for the gearbox?
09 C6 RS6 Black Saloon-stg 2 ECU and Gearbox map, secondary cat deletes, ITG filters, AP 390 brake discs.
rs6_sid
Re: high miles c6?
Post by rs6_sid » Fri Jul 29, 2016 8:06 am
Yeah has to be life guard 6 , which you can get from euro car parts febi do bottle the genuine for Vw you can get it from euro car parts and can get them down to £120 for 20l drum or get the zf filter kit and oil for £150 with the haggling ,
it's only listed under filter on their system but it does come with 7L of oil the system holds 10.8 but you won't get it out the torque converter or the valves so 7 is fine
bmw e61 m5 saloon
s3 8p stage 2
RS6-T28RPH
Re: high miles c6?
Post by RS6-T28RPH » Thu Aug 04, 2016 1:36 pm
if its any help, my 2008 has just clocked over 120k miles, had to do the oil pump last year due to internal seal failing but otherwise just normal consumables. I do a full fluid change every 10k and apart from some peculiar clicking noise i have been trying to sort from the front drivers wheel arch everything is tip top!
Esben Business IT Solutions - http://www.esben.co.uk
Esben Remapping - http://remap.esben.co.uk
2015 BMW X6 M50d (wife-transport, not allowed to touch :cry: )
2008 RS6 Avant Phantom Black - MRC Stage2 (ecu, tcu & 2nd cat bypass) 730 PS/1017 nm
2006 BMW 535d Pre-LCI - Stage 1 (340bhp)
2003 VW Polo 1.4Tdi (3pot shitbox) tuning project, was 73bhp, now 120bhp, aiming for 160bhp before it goes bang! (put in the bin)
IanH755
Re: high miles c6?
Post by IanH755 » Thu Aug 04, 2016 1:46 pm
RS6-T28RPH wrote: apart from some peculiar clicking noise i have been trying to sort from the front drivers wheel arch everything is tip top!
Could be the infamous "clicking wheel bearing" fault found on earlier RS6's.
RS6-T28RPH
Re: high miles c6?
Post by RS6-T28RPH » Thu Aug 04, 2016 9:20 pm
I wish it was just the bearing, so far we have done wheel bearing, inner cv joints as they were loose, discs & pads, control arms so running out of things to change.
Users browsing this forum: No registered users and 134 guests
