B7 RS4 Tyre pressures
mr sagman
Post by mr sagman » Fri May 06, 2016 7:40 pm
Hi Guys,
Just wondering what you recommend for f+r tyre pressures for an RS4, I have Michelin PSS and am going on a fast road trip through Wales this weekend, Any recommendations greatly accepted.
S4WON
Post by S4WON » Fri May 06, 2016 8:00 pm
Recommended is 35r 38f
I tend to run that
However.. More air can mean very slightly better handling on twisties but unless you are michael schumacher (as was) I wouldnt bother.
Dont go over 37, 40
TobyRS4
Re: B7 RS4 Tyre pressures
Post by TobyRS4 » Sat May 07, 2016 9:00 am
S4WON wrote:Recommended is 35r 38f
I tend to run that
Dont go over 37, 40
I run 34r 37f and they increase under heat to around 35-36 and 38 under driving which i find works well.
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
mr sagman
Post by mr sagman » Sat May 07, 2016 3:06 pm
Many thanks guys, all duly noted.
thesupercharger
Post by thesupercharger » Tue Jun 07, 2016 10:02 pm
Lots of forum guys say 40 psi but surely that's too much as when I put 40 in mine it was ripping chunks out the centre of the tread due to put new tyres on so a good all round pressure would be good to know and I do drive her hard
Shinobi675
Post by Shinobi675 » Tue Jun 07, 2016 10:07 pm
Sounds like you're putting in 40 cold, if so, that does seem too much.
PetrolDave
Post by PetrolDave » Wed Jun 08, 2016 8:58 am
I tend to run that
+1
I've been running PSS for the last 2 years (on my second set now) and don't see any reason not to use the pressures shown on the label in the drivers side B pillar.
Wavey Dynamicist
Post by Wavey Dynamicist » Wed Jun 08, 2016 1:23 pm
I've been running PSS for the last 20k and have just replaced the last two rears.. I run 31R 33F and have done through the life of the tyre.
Tread wear has been very even over the tyre and the pressures i run feel like a good compromise between NVH and performance. 36-38 seems too harsh in terms of NVH and are a little skittish over certain surfaces i find.. I wouldn't ever run that high.
My opinion! I don't see the argument for pressures in the high 30s.
2007 RS4 Saloon; Mugello Blue
jon_v8
Post by jon_v8 » Wed Jun 08, 2016 5:40 pm
thesupercharger
Post by thesupercharger » Wed Jun 08, 2016 9:40 pm
I'm running 255/35/19s that chart seems roughly what pressures I've been running
thesupercharger
Post by thesupercharger » Wed Jun 08, 2016 9:43 pm
What's the xl and the xl m+s all about???
PetrolDave
Post by PetrolDave » Thu Jun 09, 2016 10:23 am
thesupercharger wrote:What's the xl and the xl m+s all about???
XL = eXtra Load - which the RS4 needs due to the axle weights. Means you need 96 weight rating tyres not the standard 92 weight rating.
M+S = Mud and Snow i.e. Winter tyres
thesupercharger
Post by thesupercharger » Thu Jun 09, 2016 10:37 am
Ah I see cheers for the info dave
marc1
Post by marc1 » Thu Jun 09, 2016 10:55 am
Jaheenormous wrote:I've been running PSS for the last 20k and have just replaced the last two rears.. I run 31R 33F and have done through the life of the tyre.
NVH?
PetrolDave
Post by PetrolDave » Thu Jun 09, 2016 12:02 pm
marc1 wrote:NVH?
Noise, Vibration and Harshness - a term widely used in the car/auto manufacturing and development industries.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 782 guests
