Rs4 B7 Black
Harris.
Rs4 B7 Black
Post by Harris. » Mon May 02, 2016 11:55 pm
Deleted the old thread so ill now try again without various people jumping in saying how its not worth it and I 've missed this and that . I 've not been around these cars long so not got to involved . All I have to go on is the paperwork and history I received with the car when I got it September 2014 .
I purchased the car as it was a car on the list that I wanted to own , but now it just sits in the garage doing nothing which isn't what these cars were designed for and id like to go back to a RWD turbo car as for me there more fun and more involved ( imo) And before I get slated again , YES the car has 110k on the clock!
Black Rs4
Early 06 Plate SO cheaper TAX .
History book is stamped as
14/08/07 - 2757 miles - Audi
28/11/2008 19926 miles - Audi
25/06/09 37938 miles - Audi
02/06/10 57425 miles -Autobahnsussex.com
28/09/11 Audi removed Tyre pressure valves . Exhaust tail pipe flaps stuck - replaced £1502.80
15/09/11 71432 miles - Auto store specialist cars -Service +New front discs and pads + new locking wheel nuts
28/09/11 71844 miles - Audi Carried out ignition coil product enhancement 28E9 and replaced oil feed pipes enhancement 17D7
12/01/13 88229 miles Auto store specialist cars
22/02/13 Auto store - New under trays fitted £144.15
13/09/13 Auto store - Remove front bumper replace headlight bulbs Philips D1S £252.
03/05/14 Auto store -
Remove fuel distribution unit
Remove throttle body and inlet manifold
Replace inlet manifold valve actuator £279.96 , Oil separator vacuum solenoid valve unit price £111.97
Bleed cooling system + service
14/05/14 Auto store - Replace auxiliary belt + tensioner £169.36
29/04/14 101614 miles Auto store specialist cars
10/09/2014 102,362 Auto store specialist cars ( Prior to sale ) Along with rocker cover remover and knock sensor replaced .
It is now due a service as it is displayed on the dash screen , im more than happy to get this done back at auto store prior to sale or you can do it yourself .
I've recently had all 4 wheels painted along with 4 new tyre's
Front + rear pads changed
New front screen + wipers
Pipercross panel filter fitted
Complete front arm kit fitted , upper + lower along with drop links and track rod ends
N/S Front driveshaft gator replaced (Audi part)
Then had 4 wheel hunter alignment
MOT due September
Other than this I've not needed to do anything .
Black front grill
Black window surrounds
Black exhaust tips
Piano black interior trim with black headlining
Side airbags , passenger / drivers airbags
Sat Nav/tv with disc changer in glove box and twin SD card slots , Navigation plus (RNS-E) Don't mean a lot to me!!
Heated / electric front seats + heated rears
Centre arm rest with phone socket inside ( I've never used this ) NO nasty holes on the dash for a phone holder .
Not sure if its an extra, all the door handles light up very faint red . Nice touch .
Auto dimming rear view mirror
Dual climate control
Bi xenon Headlights - Auto plus coming home lights and DRL
Bad points , its 10 years old
Small crack under the drivers side mirror casing . Some nice guy decided to hit it and not stop !! But mirror still works fine and you can only noticed it when sitting in the car
Stone chips to front bumper + bonnet
I've been as honest as I can . It drives as it should it has good history and its also HPI clear .
Before the 100k mile haters come along ,please keep your negative opinions to yourself ,if you don't think its worth it then don't buy it . I' m not in need of the money so no real hurry if it goes it goes . And yes I got a bit lucky when buying this car ,I was in the right place at the right time as the old owner needed money asap as he was moving abroad ! (As per Sam's comment ) Hope that clears things up a little .
£15,250
Chuds1
Re: Rs4 B7 Black
Post by Chuds1 » Thu May 05, 2016 10:34 pm
Good luck with the sale Harris I'm sure you will have no problem selling it on. :thumbs:
RS4 B7 Saloon Sprint Blue, Bilstein B14 Coilovers, Milltek Cat Back resonated non valved. Spacers 8mm F and 10mm R. Headlight clear zenon lens upgrade with 5500k bulbs plus indicator orange lens delete.
FaisalJ
Re: Rs4 B7 Black
Post by FaisalJ » Fri May 06, 2016 11:43 am
I'm with you on the irrational fear of the 100K barrier.
My own car was not far off 100K when I bought it, and is on about 97.5k now. The mileage is of course a factor in a car purchase, but there are so many other things that are more important - how well the car has been looked after mechanically and cosmetically.
I'd take an enthusiast owned 100k car over a "careful lady owner" 50K car all day long.
2007 RS4 B7 Avant
Harris.
Re: Rs4 B7 Black
Post by Harris. » Fri May 06, 2016 5:08 pm
FaisalJ wrote:I'm with you on the irrational fear of the 100K barrier.
Thanks for the kind comments .
Yeah I understand the 100k barrier ,but bet your car is well looked after ? I looked at a few RS4'S before this one ,the other 2 were in the 125k bracket .
To be fair all the cars drove the same , these cars were designed for autobahns and motorways so id be shocked if a 55-60k car new wouldn't reach this point with ease but each to there own. I Don't mind not having the best RS4 out there ,I can use it, go on track days etc without crying about a stone chip :thumbs:
John Johnson
Re: Rs4 B7 Black
Post by John Johnson » Sun May 08, 2016 4:10 am
True but you have to judge each car individually and take the old blinkers off , there's some superb high milers out there and some utter utter dogs and it's the same with low milers too I'm afraid to say
Current toys in the garage
Ur quattro. lago Blue
Ur quattro. Mars red
Rs1600i
Transit custom sportvan
http://youtu.be/FWBUl7oT9sA
FaisalJ
Re: Rs4 B7 Black
Post by FaisalJ » Sun May 08, 2016 7:59 am
Absolutely, each car needs to be assessed on its own merits.
All I'm saying is that I think it's irrational to rule out a car because the mileage is above some arbitrary number.
2007 RS4 B7 Avant
toyneg
Re: Rs4 B7 Black
Post by toyneg » Mon May 09, 2016 11:57 am
My car is now on 125k and honestly feels far better now than when i bought it and it had 69k on the clock.
Harris.
Re: Rs4 B7 Black
Post by Harris. » Thu Jul 07, 2016 5:54 pm
toyneg wrote:My car is now on 125k and honestly feels far better now than when i bought it and it had 69k on the clock.
I test drove one with 125k and one with 75k and there was no difference . See you have put yours up for sale , good luck nice car .
Price reduced £15250 .
Harris.
Re: Rs4 B7 Black
Post by Harris. » Sun Aug 07, 2016 5:26 pm
New Badges fitted along with New header tank
£15000
victor2vt
Re: Rs4 B7 Black
Post by victor2vt » Sun Aug 07, 2016 7:31 pm
The absence of the wing back sports seats and a FBSW is going to be your your problem finding a buyer, IMHO.
Mint Optic Pack saloon in Daytona Grey (Now sold)
B7 RS4 in Sprint Blue (Gone to a very good new home)
Evo V1 (wish i'd kept)
Numerous M3s
rs user
Re: Rs4 B7 Black
Post by rs user » Sun Aug 07, 2016 9:01 pm
victor2vt wrote:The absence of the wing back sports seats and a FBSW is going to be your your problem finding a buyer, IMHO.
dunno about that,this is the cheapest hpi clear car available at the moment-in the right color too :beerchug:
Harris.
Re: Rs4 B7 Black
Post by Harris. » Sun Aug 07, 2016 9:19 pm
Thanks Arthur for the kind comments
I agree on the steering wheel as the FBSW makes the interior more special ,I was going to change it but finding a nice one for sale is hard plus I wouldn't know how to make the buttons work etc as for the seats I've seen mixed reviews most being the buckets look better but there a bugger to get out off an not as comfortable .Plus they attract the wrong eyes . I wouldn't want to get to my car and some bugger has pinched them .
But as you have mentioned , its HPI clear and needs nothing , for its age is very clean and well kept . I have used it a few times this week and have a few very nice comments . one guy in the petrol garage couldn't believe it had 110k on the clock and it was 10 years old and started taking photos . I've owned it 2 years and never driven it in the rain ,I spend more time keeping it dust free than driving it . I'm only selling as I mentioned before I need a high bhp turbo car again so looking at Evo 9's , just another itch I want to scratch .
As far as i'm aware the engine / map is also standard
That is my final price and I wouldn't take any less , ive seen a fair few RS4's for sale that are tatty for 17k plus . and ones that have be stolen or hit for 15k plus.
Harris.
Re: Rs4 B7 Black
Post by Harris. » Sun Aug 07, 2016 9:30 pm
A few pictures on page 116 , new badge + header tank .
viewtopic.php?f=35&t=101189&start=1725
Users browsing this forum: No registered users and 137 guests
