Hi guys.
Whats the best way to launch the R8 in a way that's not too aggressive? I'm going to santa pod in April and want to do a few runs but dont want to go crazy. The car spins up even with esp on so is it still best to turn off and are suspension settings likely to make any real difference?
Cheers.
Launching.
Launching.
2006 B7 RS4 Mrc stage 2
2000 evo VI tommi makinen red
1999 Evo V 370bhp white
1995 e36 m3 3.0 green
1988 Saff cosworth 2wd white
Re: Launching.
If the track is not too green and its warm you should get plenty of traction. Just watch out early on or if its cold. Might be worth dropping a few PSI out too.
Re: Launching.
depends on track temperatures and if its glued in well or not, for mechanical sympathy in 4wd id recommend a soft launch i.e. launch at lower revs to fully engage the drivetrain for a split second before full throttle otherwise youll end up riding the clutch out and the slight roll off the line will limit wheel spin.
or however if you don't have mechanical sympathy in mind, or have deep pockets do a couple of runs and just increase the revs at each launch point, start at say 3-4k and go in 1k increments and let the time boards dictate what is fastest.
Sprint Blue B7 RS4 - Black/Titanium optics, Anthracite OEM 19's, De-resonated OEM Exhaust, TTRS FBSW, MRC Stage 2 De-flapped manifold, Full Carbon Clean, MRC Stage 2 Re-map, 431.5 BHP...... must...not...spend....more...
Users browsing this forum: No registered users and 46 guests
