C5 RS6 £8750, wagners,milltek,KW's
kwalker705
Post by kwalker705 » Tue Jan 26, 2016 9:19 pm
Up for sale is my audi RS6 . Loads of new pics. Lots of new parts in the last few months and a price drop.
Purchased over a year ago as a very mechanically tired example in need of some love and attention. The car has had thousands spent on it during my ownership and many of the issues and problems have been repaired , but I now need something more suitable for towing so the audi must go .
MOT till march 2017
The car has recently turned 120k miles and still runs smooth. the car is smoke and rattle free. When i purchased it the car had already had the problematic DRC suspension changed for some KW V3 coilovers. ITG panel filters were also fitted. There is a reciept in the service history for a gearbox rebuild as well. So that ones been taken care of.
Since purchase the following maintenance or repairs have been carried out (all audi dealer parts unless stated)
Engine and transmission
Gearbox filter and o-rings and sump gasket (changed every 3-4k miles)
Gearbox oil drained, gearbox flushed, new oil (flushed every 3-4k miles)
Engine oil and filter (changed every 3-4k miles , 1st at 114k miles, 2nd at 117k miles)
Timing belt changed,all Timing belt tensioner's and rollers changed,Water pump changed (115k miles)
Front crank seal changed
Aux belt and tensioner's changed
Large number of bolts,hose clips, brackets and o-rings renewed when changing timing belt and water pump.
Cam cover gaskets changed
Coolant changed out along with new bubble tube from radiator to expansion tank
Power steering fluid changed
1 new injector and injector o-rings
New Wagner engineering silicone intercooler hoses
New Wagner engineering intercoolers
New Wagner engineering carbon fibre intercooler shrouds
New Wagner engineering front bumper grills
2x GFB recirculation valves.
NGK spark plugs x8
New Milltek non-resonated cat back exhaust (sounds incredible, turns heads and always gets good comments from passengers)
Exterior
New headlight bulbs
All headlight brackets repaired (prone to snapping/breaking)
headlight lenses restored
Seat leon R front lower bumper splitter
New driver side mirror glass
shark fin DAB aerial
Interior
New arm rest
genuine audi carbon fibre interior panels (centre console handbrake cover. 4 pieces)
New sunvisor retaining clips (previous 2 were snapped)
Pioneer double DIN stereo with Ipod connect etc etc
connect 2 wiring harness (steering wheel controls there incase you want to upgrade)
fitted RS6 mats
New menu control button for centre console
New mirror control switch in centre console
Brand new driver door lock
Brand new door latch mechanisms on both front doors
Brand new second key
Chassis
EBC red stuff front brake pads
2x brand new front brake discs (zimmerman drilled)
Front calipers refurbished in gloss black
EBC red stuff rear brake pads
2x brand new rear brake discs (zimmerman drilled)
New rear brake caliper
goodridge stainless steel braided brake hoses
Motul R600 brake fluid change
H&R 10mm spacers
H&R longer wheel bolts
brand new locking wheel nut set
4 wheel alignment carried out as per audi specifications.
Rear diff oil changed
4x wheels refurbed and powdercoated. (wheels treated to G-techniq C5 wheel armour for easy cleaning)
4x brand new michelin pilot sport 3 tyres
This car is bags of fun due to the uprated suspension and high BHP output. It also ticks all the boxes as a family car with ample boot space and spacious cabin. The spec on the car is huge and has heated front and rear seats as well as the BOSE upgraded stereo. This coupled with the pioneer headunit makes for great listening. Great car for everyday driving, weekend use, motorway driving etc etc and all the big nasty bills/repairs have already been covered either at my or the previous owners expense. (well into £4500 spent on it in the last 12 months alone) Only thing the car can benefit from now would be a tidy up of the bodywork.
The car has a partial service history and many reciepts from reputable audi specialists as well as for all the parts fitted in my ownership.
I am open to part exchanges on something of a similar value or something with cash my way (ideally after a 2007 onwards leon cupra R , or something suitable for towing) Test drives are welcome but you must have valid insurance and the cash in my hand before you get to enjoy it.
Buyers can be collected from aberdeen train station or airport.
Private plate has now been removed from the car and its now on an HC04 reg number.
£8750. Open to possible P/X
kwalker705
Re: 2004 RS6 avant.
Post by kwalker705 » Sat Jan 30, 2016 11:11 pm
Just looked back on VCDS logs.
Gearbox switch fault is not F125 but is F189 switch fault which is possibly the magnet inside the shifter itself coming loose.
Will investigate and update once I've been able to look into it.
kwalker705
Re: 2004 RS6 avant. Mugello blue.
Post by kwalker705 » Wed Aug 24, 2016 1:39 pm
checked into the F189 tiptronic switch highlighted in Vagcom. Stripped and cleaned the magnets under the auto shifter cover and that seems to have the problem fixed. Not seen the issue arise for a few months now.
Car is still for sale. Better pictures, updated description and another few ££££ of parts fitted to it since the original advert.
kwalker705
Re: 2004 RS6 avant. Mugello blue. New tyres, brakes, timing
Post by kwalker705 » Wed Sep 21, 2016 4:34 pm
Still for sale and open to offers
Jayjay101
Post by Jayjay101 » Thu Sep 22, 2016 7:38 pm
Wish you were closer!!
kwalker705
Post by kwalker705 » Fri Oct 14, 2016 4:29 pm
can easily meet buyers at aberdeen train station or airport. So dont be put off by distance etc to view.
kwalker705
Post by kwalker705 » Fri Dec 30, 2016 9:45 pm
Price now down to £8750 for a quick sale.
kwalker705
Re: C5 RS6 £8750, wagners,milltek,KW's
Post by kwalker705 » Mon Feb 06, 2017 6:15 pm
Brand new radiator fitted to the car today
New coolant and power steering fluid also.
Grab a bargain folks
kwalker705
Post by kwalker705 » Tue Feb 21, 2017 4:48 am
New 12 month MOT on the car along with 4x new suspension arms/bushes that were required for the test
kwalker705
Post by kwalker705 » Thu Mar 09, 2017 9:55 am
Car still available. New external temperature sensor now fitted. This car is now mechanically 100%. I dont understand why its still not sold.
Post by chunky79 » Thu Mar 09, 2017 10:35 am
Only thing I can think of is location. Sadly some folks won't travel for the right car.
kwalker705
Post by kwalker705 » Fri Mar 10, 2017 9:53 am
id never really considered the location an issue.
Phant0m
Post by Phant0m » Sat Mar 11, 2017 3:30 pm
Hi
Would you consider a partial exchange?
2007,70k,FSH, Renault Megane Sport R32 TeamF1(one with LSD), Stage 2 tune by respected tuner, all quality parts and needs nothing, just in for two front window regs n looms, well over a grand for that, I always have my cars A1. YOKAHAMAS, FERREDO 2500, BREMBO etc etc.
Liquid yellow. I dont have it up for sale but looking for a C5 RS6 or B5 S4 stage 3 and an exchange might swing it.
kwalker705
Post by kwalker705 » Wed Mar 15, 2017 6:52 pm
deposit now taken.
Post by Ian_C » Wed Mar 15, 2017 6:55 pm
Nice one mate
Users browsing this forum: JRC1 and 29 guests
