Require latest 2016 sat nav update for Audi MMI 3G HDD
- xxx_mojo_xxx
Does anyone know where I can download the latest Audi satnav updates from?
Pls PM me if necessary. Appreciate the help.
P.S. How does one check the map version and what is the latest version?
Thanks,
Mo
Thanks,
Mo
Skiptowncat
- 1st Gear
Re: Require latest 2016 sat nav update for Audi MMI 3G HDD
Just done mine today.
You'll need k0257 firmware
http://cartechnology.co.uk/showthread.php?tid=12093
- xxx_mojo_xxx
Seems complicated and dangerous. What improvements are there with the firmware and map updates? Are they significant?
Skiptowncat
- 1st Gear
Depends how often you use the navigation. I use it a lot so like to keep it up to date.
It's actually pretty easy to do on a 3G unit, it's 3G+ that is a bit tricky.
- xxx_mojo_xxx
How do I know if I have a 3G+ unit? Sorry I'm a total noob.
Skiptowncat
- 1st Gear
3G+ has online stuff like google maps.
Skiptowncat
- 1st Gear
Press "car" button then "info" select settings using the top right button and there should be a menu there called version information.
- xxx_mojo_xxx
Ok, mine does NOT have Google maps.
Skiptowncat
- 1st Gear
Check the firmware version via the steps above
