Hi guys just looking at these rotor alloys advertised on here for my b8 RS4 however they are on a Audi rs4 b7? I don't know weather they will fit my b8 Audi rs4 or not as I went onto the old eBay checked it says that rs4 b7 wheels will not fit a Audi rs4 b8 as it is different?
Could someone please confirm weather Audi rs4 b7 rotors will fit onto a Audi rs4 b8?
Much appreciated
Will b7 RS4 Rotor Alloys fit a b8 RS4?
- Surrey Sam
Re: Will b7 RS4 Rotor Alloys fit a b8 RS4?
You need to find out the specification of the alloys in question. Ask for a photograph displaying the inside view of the mounting face and all the associated codes and numbers. There you will find the wheel dimensions and offset. Post that picture and the people here can confirm for you.
Much appreciated for the advice guys the chap said the following
Yeah mate there off a b8 rs4
I will get the offset and update the thread
No, I'd say they will almost certainly not fit. The B7 wheel has a centre bore size of 57.1mm and the B8 has a centre bore of 66.6mm. It would work the other way round with spogits (i.e. B8 wheel on a B7). Unless of course there is a lot of slack on the B7 but if this was the case it would most likely wobble on a B7.
Sorry, I just re-read your original post. The B7 never came with rotors so if they are the 20" rotors then they are most likely from a B8 so you will need to just remove the spigots and they should fit. As others have said, get the part number is the best way to tell.
Users browsing this forum: Thedarkside and 100 guests
