Help! suspected coolant leaking - Pic
ChrisW
Post by ChrisW » Sat Nov 28, 2015 4:11 pm
Hi all,
I just noticed at the garage a slick on the concrete underneath the front bumper, seems to be coming from behind the driver side aux rad.
You can see the drip forming at the bottom of the arch liner. Its coming out at quite a rate!
Can I drive around with a bottle of water to top up for now until i book it in on Monday, or is putting water and not kosher coolant in the tank a definite no no in these cars?
Current: 07' B7 RS4 Avant
Previous: Mk2 Golf VR6 conversion, Mk2 Golf GTi 16v, Mk2 Golf 1.6 GL Auto, Mk3 Golf R32 conversion, BMW Z4 Coupe, BMW 430d, Audi S3, Defender 90 XS, Alfa Romeo 145
Grandadg90
Re: Help! suspected coolant leaking - Pic
Post by Grandadg90 » Sat Nov 28, 2015 4:26 pm
Hi
Most likely the aux rad leaking. Its a bumper off job. Common fault. Keep an eye on your coolant level however.
Daytona Grey, Bilstein Coilovers, Pre-cat delete, Centre resonator delete, IM flaps/vains delete, Interior/Exterior LED kit, CAI, Black Optics.
Other car: Bread Van
davers6
Post by davers6 » Sat Nov 28, 2015 4:34 pm
Water is fine for a day or 2
ChrisW
Post by ChrisW » Sat Nov 28, 2015 4:54 pm
davers6 wrote:Water is fine for a day or 2
I'll keep some water in the boot and get it booked into Unit 20.
Thanks all.
Baz999
Post by Baz999 » Sat Nov 28, 2015 5:01 pm
There is a diy for aux rad removal very easy to do and also taking bumper off is not hard of you are good with screwdrivers
ChrisW
Post by ChrisW » Sat Nov 28, 2015 6:53 pm
Am I right in thinking I can do away with one of the rads in favour of a CAF?
Grandadg90
Post by Grandadg90 » Sat Nov 28, 2015 7:58 pm
Absolutely, CAF's are a great mod. Extra noise, you will love it.
TimDogg
Post by TimDogg » Sat Nov 28, 2015 8:03 pm
Why is the CAF extra noise - sorry?
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
Briggy
Post by Briggy » Sat Nov 28, 2015 8:07 pm
ChrisW wrote:Am I right in thinking I can do away with one of the rads in favour of a CAF?
Yip. £45 for the kit of fleebay and 2 hours' labour at your trusted indie if you don't fancy the job yourself. Well established mod, so no need to worry about "what ifs".
Cheers,
Bryan
ChrisW
Post by ChrisW » Sat Nov 28, 2015 8:36 pm
Thanks for that, just any of the universal ones?
like this -> http://www.ebay.co.uk/itm/UNIVERSAL-PER ... Swu-BWO1gb
TAB1S
Post by TAB1S » Sat Nov 28, 2015 9:51 pm
http://www.ebay.co.uk/ulk/itm/370782118423[url]
89mm in black i think is most commonly used :thumbs:
RS4 B7
MRC stage2 436ps-487nm
Revolution intake, custom CAF, carbon clean, deflaped manifold, JHM manifold spacers, Forge oil cooler, Forge spacers, full de-cat, Scorpion cat back, Trup's LED's, 20' S5 wheels, KW V3's.
Launch control & flat shift :mrgreen:
Post by MikeFish » Sat Nov 28, 2015 11:24 pm
As above, you don't want to move the actual air filter, just add a pipe to direct cold air from the fog light grill up into the air box. If you have a standard airbox I think the opening is about 89mm so that is the right size to go for, but I have the Revolution air filter kit which is open at the bottom and I found a big difference when I swapped the 89mm hose for a 102mm hose with trumpet.
ChrisW
Post by ChrisW » Thu Dec 03, 2015 10:01 am
It wasn't coolant, it was oil. The cooler pipes are goosed, goodbye £1200!
mikep99
Post by mikep99 » Thu Dec 03, 2015 10:11 am
have a read here - viewtopic.php?f=35&t=116672
ChrisW
Post by ChrisW » Thu Dec 03, 2015 8:18 pm
Bloody pipes! Fortunately the usual excellent service from Unit 20 has pulled me out of the <beep> as I'm due to go away with the misses this weekend, top work.
Users browsing this forum: Majestic-12 [Bot] and 76 guests
