Lowering Air Suspension
Paulm
Post by Paulm » Fri Nov 20, 2015 6:51 pm
Car is on the boat, not long now.
Anyone used VCDS to lower their suspension yet?? As I have the 20" wheels I want them to fill the arches.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
911 Turbo Remapped. Hated it
RS6 V10 700BHP crazy
Re: Lowering Air Suspension
Post by MikeFish » Fri Nov 20, 2015 7:20 pm
What a coincidence. I started to research this topic just before I left work so interested to see what is possible
TTE Si
Trader (Expired)
Post by TTE Si » Fri Nov 20, 2015 8:04 pm
pretty sure i can do this as done my A8 D4
Paulm
Post by Paulm » Fri Nov 20, 2015 8:16 pm
Borrowed from another site :oops:
As said looks like its possible
how to lower you car 17mm
I finally accomplished lowering the S6 with VCDS. Some said it can't be done, but it most definitely worked for me. It should be entirely reversible in case you decide to revert the settings. All research was done through Google and playing around with software settings, none of this information was provided by Audi or Audi dealers. This method is an alternative to Lowering Links (which are great if you don't have the electronic tools/would rather go the mechanical route), or H&R lowering module (which is also great, and allows for on-the fly adjustments vs. having to mess with car systems).
I figured that since all the tools and information required to do this have already been made public on the internet, it is just matter of time until someone posts a step-by-step guide, so here it is.
DISCLAIMER: I am not responsible for anything that these changes may cause, or if your car breaks, or if dealership finds out and denies your warranty if something goes wrong... Try this at your own risk.
0) Set your car to "Auto" mode (not dynamic, comfort, etc.). Make sure car is on level ground. Close doors. If any doors are opened during the procedure, it will be interrupted. Make sure your car is NOT in a towing or tire changing mode.
1) Load up VCDS, go to Module 34 - Level Control
2) Go to "10 - Adaptation", take note of 4 values titled as "Body height front left wheel house edge" - mine were set to around 384 from factory.
3) Take the values you noted above, and ADD your desired drop in millimeters (mm) to each value, write it down... So if your left front wheel was 384.5, your new value will be 401.5. Repeat for the other wheels. It is not critical to be 100% precise here, rounding the values is fine. Note that maximum Audi-approved drop is 17mm from what I've gathered. You can go lower, but if you go lower, you're also affecting other systems, such as cameras, adaptive cruise, etc., so be careful.
Technically, if you want this procedure to be done properly, instead of taking existing values, you will measure all 4 wheels after completion of the step 7, and then add your drop value if desired. Suspension height values are measured from the center of the wheel to the edge of the fender.
4) Go to Security Access, enter code provided on the following website, under VCDS section, item #3 (I'm not posting this directly to avoid spreading sensitive data, although it's been posted on other forums in past) http://www.stemei.de/pages/coding/au...ng-des-aas.php
5) You should get a message stating that security code has been accepted - if you don't, something failed, stop doing what you're doing
6) Go to 04 - Basic Settings
*** IMPORTANT: Whatever you do, DO NOT select "Reset All Adaptations" - this is not undoable, and will require a visit to the dealer. ***
7) Select "Activate Level Control", hit "Go", wait for it to complete (should only take a second, until it says "not running").
8) Select "Delete Calibration For Level Control", hit "Go", wait for it to complete, your car will throw a fault code and you will see an error message stating Air Suspension Malfunction - this is normal.
7) Select "Start Up to Reference Level", hit "Go". This step will take about a minute, and your car will go up/down during the process (you'll hear hissing noises). Wait for it to complete, until it says "not running".
9) Select "Go Back", go to "10 - Adaptation" on the previous screen.
10) Next you will need to enter new adaptation values for all 4 wheels. Select "Body height front left wheel house edge", then enter new adaptation value, and hit "Do it", then repeat for the other 3 wheels. I did it in the order the menu was arranged (FL, RL, FR, RR) - not sure if the order matters, but just in case. Each time you enter a value, you should get a message stating that it has been accepted.
11) After you're done entering adaptation for all 4 wheels, select "Go Back", and return to "04 - Basic Settings" again.
12) In basic settings, select "Calibrate Level Control" and hit go, it will take a few seconds. Wait for it to say "not running". If you get an error during this step, you either missed a step, or something went horribly wrong.
13) Select "Activate Level Control", hit "Go"
14) You're done, now go to "02 - Fault Codes" and Reset codes.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Paulm
Post by Paulm » Fri Nov 27, 2015 11:53 pm
On the pre-facelift can you lower and raise the air suspension from the Audi interface? I can raise and lower mine. Looks good on the 20" wheels I wonder if it's slightly lower than the pre-facelift cars? Going for the 20" wheels was a worry but I am happy with the look.
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Post by MikeFish » Sat Nov 28, 2015 12:12 am
I think you can raise the car on both pre and post facelift to give better ground clearance and then return it to normal height but that is not the same as lowering the car.
Paulm
Post by Paulm » Sat Nov 28, 2015 8:09 am
It seems to run low all the time. Looking on the interface the option is always to raise the car. Goes up by quite a bit. Not sure I can lower it much anyway, maybe a 10 to 15mm, it would look pretty slammed at that
BMW 540i
2018 GTR
F90 M5
X3MC
RS3 Saloon
RS3 8P Rubbish
Users browsing this forum: Google [Bot] and 229 guests
