No anti-theft bolt key?
4.2 V8 32v FSI - 444 bhp
jjdsyd
Post by jjdsyd » Sat Oct 03, 2015 12:15 am
Went to my local mechanic today to have some spacers fitted. When we went to retrieve the antitheft bolt from the boot, we discovered it is not there. No tire iron either. There is only a jack, and the compressor and goo for plugging leaks.
I guess I am going to have to go to the dealer and purchase and antitheft key. That seems pretty crazy to me. Surely if they deliver a new car with wheel locks they should give the owner of the key?
johnnydog
Re: No anti-theft bolt key?
Post by johnnydog » Sat Oct 03, 2015 12:52 am
I would think an Audi dealership would supply a replacement locking wheel nut key and brace foc, especially as it's a new car. It's not an item you could reasonably be expected to check when you took delivery of it, but I wouldn't mention that you were intending to fit spacers....!
If you are desperate to get the wheels off, then all dealerships have a master set. I have known them to loan the correct master key and they just replace it when the replacement comes in.
jjdsyd
Post by jjdsyd » Sat Oct 03, 2015 1:16 am
Ok thanks. But, did you guys get them with your cars? Because in my car it seems as though it was never intended to be there. I guess because there is no spare...
RIV
Post by RIV » Sat Oct 03, 2015 1:47 am
So its not under the access panel at the back off the boot, inline with the top cover?
jjdsyd
Post by jjdsyd » Sat Oct 03, 2015 6:58 am
Thanks Riv. I am not sure exactly where you mean. But I cannot find the bolt or the tyre lever anywhere or any place where it looks like it should have been.
aled_31
Post by aled_31 » Sat Oct 03, 2015 9:08 am
It will be there, just not where you are looking!! I called Audi assist out to remove a wheel with flat tyre as I was convinced I didn't have a locking wheel nut or tyre brace. Chap found it very amusing!! :oops:
Remove the boot floor cover as you would normally. Once removed you will notice that there is still a section of the boot floor left in place (immediately behind the back seats). This section is hinged. You will notice a cut out in the centre of it which you can get your fingers into and open the compartment. Locking wheel nut and tools will be kept in there.
Current:
B9 RS4 Avant in Missano
1991 Mk2 Golf GTI 8v, Big Bumper in Oak Green
1960 VW Beetle 1200 (6 volt, 34hp!)
1999 Porsche Boxster 2.5
On Order:
B9.5 RS4 Avant in Daytona
Previous:
3 x B7 Avants in Sprint, Phantom and Daytona (Loved that car!!)
3 x B8 Avants in Daytona, Phantom and Ibis
2 x B9 Avants in Missano (x2), Daytona
1 x B8 S4 Avant in Sprint
Snotsicle
Post by Snotsicle » Sat Oct 03, 2015 9:19 am
When I swapped for winters last year, the guy at the tyre fitters watched with some amusement as I rummaged in the obvious location in the boot trying desperately to find the key. Once he'd finished his cuppa he calmly wandered over, lifted a hidden flap and showed me where I should have been looking in the first place.
He said that I wasn't the first and wouldn't be the last to make that mistake.
Current: Daytona Grey '14 RS4 Avant +most options
Previous Audis:
Phantom Black '07 B7 S4 Avant Tip
Akoya Silver '03 B6 A4 Avant 3.0 Quattro Tip
Ming Blue '99 B5 A4 Avant 2.8 Quattro Tip
Laser Red '97 8L A3 3dr 1.8T
Assorted junk too embarrassing to list
jjdsyd
Post by jjdsyd » Sat Oct 03, 2015 10:16 am
Thanks you guys are legends. I feel pretty stupid. Although, Audi could do a lot better job of explaining it in the manual!
RIV
Post by RIV » Sat Oct 03, 2015 11:11 am
This had me baffled for a while, stuck on the hard shoulder of the m40 with a flat tyre
:audibash:
Users browsing this forum: Google Adsense [Bot] and 45 guests
