It's clutch time.
boombastik
It's clutch time.
Post by boombastik » Fri Sep 18, 2015 6:56 pm
Right folks.
I've decided it's time to change the clutch. After a bit of spirited driving a month ago the peddle stuck half up. And ever since then it's only done it 3 times more but it feels a lot different than what it used to be.
So where's best to get the clutch kit and obviously change the flywheel at the same time. What about the slave cylinder should this be changed also is there anything else I should be doing while the box is out ?
Doing this at my cousins garage with my cousin in a few weeks. So got time to order the parts.
Should I go after market or stick with Audi parts ?
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
boombastik
Re: It's clutch time.
Post by boombastik » Mon Sep 21, 2015 8:10 am
been doing some research and JHM do a lightened fly & clutch kit & a slave cylinder as well so think i'll order this from the states
vwgolf32
Post by vwgolf32 » Mon Sep 21, 2015 12:56 pm
I had the same problem with clutch pedal sticking when giving it some stick.
I was just going to change clutch and bearing and vacuum pipes. Decided to change flywheel at the same time.
Got all parts from local audi garage. No more problems with the clutch sticking since fitting 12 months ago.
Daytona RS4 B7 saloon
R32 Golf
911 C4S
EVO VI
RS2
Various fast fords
boombastik
Post by boombastik » Mon Sep 21, 2015 1:01 pm
vwgolf32 wrote:I had the same problem with clutch pedal sticking when giving it some stick.
did you change the slave and the pipe as well ?
vwgolf32
Post by vwgolf32 » Mon Sep 21, 2015 1:05 pm
Yes we changed the pipes but not the slave.
Car had done about 66000 when they were changed.
Hope this helps
R32 Golf
911 C4S
EVO VI
RS2
Various fast fords
boombastik
Post by boombastik » Mon Sep 21, 2015 1:08 pm
cheers
I plan to change the slave guess i'll do the pipe as well I don't suppose you have the part numbers on an invoice do you?
boombastik
Post by boombastik » Thu Sep 24, 2015 11:52 am
received a list of part numbers from MRC on Tuesday, I have a guy with a trade parts account so have ordered all parts to replace the clutch coming in at £1211.79 for everything
Ellis
Post by Ellis » Thu Sep 24, 2015 1:02 pm
Sticking with OEM clutch/flywheel then aye?
boombastik
Post by boombastik » Thu Sep 24, 2015 1:23 pm
aye MRC said the standard set up is perfect for what I use the car for and if I go for a lightened fly it will rattle a bit and the uprated clutch will give it an on or off feel so decided to stick with stock for the driveability
ASC
Post by ASC » Thu Sep 24, 2015 5:46 pm
You know when we did the CAF's and you did yours first so we knew what we were doing for mine yeah? Ahem... :wink: :wink: :thumbs:
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
boombastik
Post by boombastik » Thu Sep 24, 2015 6:00 pm
ASC wrote:You know when we did the CAF's and you did yours first so we knew what we were doing for mine yeah? Ahem... :wink: :wink: :thumbs:
Haha I was thinking about that like. Honestly if I find this to be straight forward enough and done in a day then I will do provide a service for our wee band of brothers :bigblink:
Might need more than beer tokens tho :beerchug:
boombastik
Post by boombastik » Wed Oct 21, 2015 9:18 pm
Well that's the clutch replaced.
Quite an easy job once all the stuff that needs to come off is off would have took me and my cousin 6hrs however broke a down pipe stud and the rest were corroded badly so had to use heat to get them out and replace them which took a couple hours
One mistake I made was when pulling out the box I didn't realise that the engine position sensor needed to come out and managed to break it so had to wait a day for Audi to deliver one
Did some sums and total cost including the sensor and 2 days trailer hire and engine oil and filter change
£1211 all parts
£108+ vat for sensor
£21 oil filter
£100 trailer hire
£250 labour
£1700 all in and the satisfaction that I've done it myself
I took a few pictures during the process I'll post them up when I get time
R1RS4
Post by R1RS4 » Thu Oct 22, 2015 9:10 am
So what does it actually feel like apart from the clutch not staying down?
Just wondered with the FW replacement did it smooth out gear change vibration when full on the beans?
Well done for taking the job on, would love to do this job if I had the hyd ramps
RS4 B7 Avant,2007
boombastik
Post by boombastik » Thu Oct 22, 2015 9:28 am
Instantly noticeable the bite point is now only about 1" off the floor
I replaced the FW with oem so can't say I've noticed any difference on that
I'd recommend if doing this yourself you do need a mate with a garage as I think we used every tool in the box and not a hope in hell doing this in a drive on wheel ramps or stands
Pistolpete2543
Post by Pistolpete2543 » Thu Oct 22, 2015 9:36 am
It would definitely be interesting to see your write up with pics showing just how much is involved in the job. I think my clutch will need doing soon, 78k miles on the original. Not a chance I would tackle it myself though!!
Users browsing this forum: Google Adsense [Bot] and 95 guests
