head unit fitting kit
Baz999
Post by Baz999 » Wed Aug 26, 2015 3:30 am
Who has change the stereo to an aftermarket one and if so what fitting kit did you buy if you kept the bose system
Baz
MB2
Re: head unit fitting kit
Post by MB2 » Wed Aug 26, 2015 3:10 pm
I think you will need something like this -
http://enfigcarstereo.com/ENFIG_RWH_AUD2_HILO.html
At least with 4 x RCA if not the electronics, but I have never done the conversion so can't say for sure.
Post by MikeFish » Wed Aug 26, 2015 3:42 pm
I used the audi a4 alpine fitting kit that was an option with my head unit.
Although I don't use the Bose, I still use the Bose wiring so for all intense and purposes it thinks I'm still using it.
It also has some RCA connections you can unplug and use to connect to an aftermarket amp instead if you change at a a later date.
Post by MikeFish » Wed Aug 26, 2015 3:43 pm
The only thing I couldn't figure out is how to use the built in GPS antenna. Pretty sure it should be a case of just buying a simple adapter but still not done it.
Baz999
Post by Baz999 » Wed Aug 26, 2015 8:47 pm
Thanks for that guys. Been looking on the connects2 website and there was 3 different face plate adapters, I'll get the cheap one and hope it matches the plastic colour.
Baz
FaisalJ
Post by FaisalJ » Wed Aug 26, 2015 9:53 pm
If you want to match the colour to the dash get hold of the model spray paint mentioned in the aircon button how-to guide. It's a few quid on eBay. My installer did a couple of coats on my surround and it matches perfectly.
2007 RS4 B7 Avant
Baz999
Post by Baz999 » Wed Aug 26, 2015 10:00 pm
I read that guide so will do that if it doesn't match
