On which side are brake pads worn or can I disable message?
IanH755
Post by IanH755 » Thu Jul 23, 2015 8:45 pm
Hi all, I have C6 RS^ with an intermittent Brake Worn caution on the dash that is down to some dodgy wiring somewhere in the body (hub area wiring checked out ok). It's had new pads fitted by dealer under warranty but the fault still there. Can VCDS detect which side is giving the brake worn signal? It'd help narrow down this annoying fault.
If not, is there a way to disable the warning so it doesn't show again?
RossDagley
Re: On which side are brake pads worn or can I disable messa
Post by RossDagley » Thu Jul 23, 2015 10:26 pm
No to both. Sorry.
Previously:
Trups
Trader (Expired)
Post by Trups » Thu Jul 23, 2015 11:05 pm
Only one side has the warning sensor, full lock and have a nose under if you can.
You may be able to code the warning system out, you will find that in the instruments module.
RossDagley
Post by RossDagley » Fri Jul 24, 2015 6:52 am
Both sides of the car have sensors (one sensor per caliper) and can't be coded out as I said above.
Previously:
IanH755
Post by IanH755 » Fri Jul 24, 2015 8:10 am
Hmmmm, back to wiring checks then, thanks for the info Ross!
IanH755
Post by IanH755 » Sat Jul 25, 2015 4:22 pm
Well the new DS2500 pads I've just fitted don't have any wear indicators so I chopped the plugs off the ATE pads that were fitted, connected the ends together to create a loop and refitted the plugs and the message has disappeared so hopefully it was something in the sensor loom rather than the car loom. Although to be fair it was intermittant before so I'll see if the message is still off in a weeks time.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 20 guests
