Hi,
As per the post title Have of you removed silencers from standard exhaust?
I'm looking for a little more noise without loosing the oem look.
Mat
I heard some people in France removed the front silencer and it makes a great sound after, no drone and oem look.
Re: Have of you removed silencers from standard exhaust?
A few people on here (and SRS) have removed the front silencer 'suitcase' box and replaced it with a straight through X pipe. Its a great value mod that gives you probably just as much 'voice' as a £1500 cat back resonated Milltek whilst maintaining the OEM look. Magnaflow seem to be the best.
http://www.ebay.co.uk/itm/111414754173? ... rmvSB=true
What is the best option : x-pipe or normal pipe to replace front silencers ?
I'm sure you could have two completely separate pipes in parallel if you wished.
In fact there are 2 possible options:
1. Remove the 2 Donwpipe Resonator and replace them by normal tubes
2. Remove the Central Resonator and replace it by x-pipe resonated like this one: http://www.magnaflow.com/02product/disp ... mber=11385
Here is the result: https://youtu.be/mHWgYrJ9vfA
What is the best based on your experience
Julien
Julien
Or remove both the down pipe and centre resonators? Or will that make it too loud?julieng wrote:In fact there are 2 possible options:
Julien
Hi. I’m new in here. I have an Rs4 B8.5 and I’ve already done the middle resonator delete and had an X pipe fabricated to replace it.
I’m now considering removing the front resonators and having a H pipe configuration out there instead to make it louder but also hopefully make it drone free.
Has anyone else done this or know if this would work?
Users browsing this forum: No registered users and 171 guests
