How do i wipe out reg in my photes
How do i wipe out my car reg in the forum photos.
many thanks
many thanks
Re: How do i wipe out reg in my photes
Select the photo on your phone then rub really fast back and forth across the reg number. If you do it fast enough it will erase that part of the photo, if you do it too slow it will just smudge.
Il try that.
Many thanks
Many thanks
audiandi wrote:Il try that.
Many thanks
That worked on my iPhone 6 but not on my 4S.
Do you have a screen cover on your 4S? You'll have to peel it off first.Shoppinit wrote:That worked on my iPhone 6 but not on my 4S.
I used my felt pen in the end and it worked, although i can't get the pen mark off my phone now !!
Turns out I was rubbing from right to left, but you have to rub from left to right for some reason.bam_bam wrote:Do you have a screen cover on your 4S? You'll have to peel it off first.Shoppinit wrote:That worked on my iPhone 6 but not on my 4S.
Put the cursor over the screen mark and then use backspace on the keypad. That should delete it.audiandi wrote:I used my felt pen in the end and it worked, although i can't get the pen mark off my phone now !!
Sorted.....
Great! Now put your badge in the correct position.
- Mr Footlong
Needs fat arches.
Current:
Gone:
Gone:
Im going to put spacers on and see if that makes it look a bit better (not sure what size)
Thanks for the S4 badge advice, never noticed it before.
cheers
cheers
What spacers are you getting for your arches? I need some for mine.
7 or 8 front and 10 rear.
Not sure what make yet, theres a few makes on the market I've seen( still researching)
I'll keep you informed.
Users browsing this forum: No registered users and 98 guests
