power steering pump
power steering pump
Anybody know the oem number for power steering pump...mine is a little noisy ..getting a little concerned
Thanks in advance
Thanks in advance
E28 M535i
E39 M5
IMPREZA 22B
E39 M5
IMPREZA 22B
Re: power steering pump
Lots of things can cause that noise, from a loose clamp to a small leak somewhere. The noise is generally pump cavitation. Mine has been noisy to VERY noisy on cold winter starts since I got the car 4 and a half years ago. Still no sign of the pump actually giving up, and on occasion it was noisy for miles even driving in a straight line. I forget about it when spring rolls around and it's quiet again. Many fluid flushes have been done with varying degrees of improvement, never lasting long.
981 Cayman GTS Gray/Orange.
My youtube
My youtube
sorry to jump on someone else's old post but seems relevant...
my PS pump? started making a noise recently as well, on inspection I could see a glittery look to the PS fluid. (Im assuming its the pump as the noise increases when turning the steering when stationary and goes away when not under load).
Since my cars already sat with the engine and box on the floor (gearbox rebuild) Ive just told them to go ahead and replace the PS pump as well (hardly going to make a great deal of difference to the price in the grand scheme of things!).
Any thoughts?
Any thoughts?
The glitter sounds like swarf. Could be pump or rack. Don't feel like changing the rack while it's all in bits, too?
My pump is a teeny bit noisy first thing, going slow, first gear and tight turning. I've done a few fluid changes and my fluid has a lovely green tinge to it just like the stuff straight out the bottle.
There was a chap in the US who rebuilt one for a S6 (they looked very similar), but I don't know where you'd get a rebuild kit. Also it didn't get rid of the noise.
Daytona RS6 Avant
hmm, well ill take a hit on replacing the pump first, at least the rack (I assume!) should be easy enough to replace even once the engine and box are back in.
Got a feeling the rack is an engine out job. Could be wrong though.
The rack is about £400 to rebuild but it's an engine out job unless you can get around the £1500/$1500 bolt thing. I think it was a term coined by RS6.com in reference to trying to remove the center bolt with the engine is situ, I think someone did manage it, then held the bolt in question aloft and said "beholden, the $1500 bolt". Ameritards.
huff.... ! is there anything on this car that does require the engine to be removed first?!
Thanks for that, ill speak to them now to before its too late.
Thought panda had her rack replaced without removing the engine.
Daytona RS6 Avant
Is that a euphemism?Nobby wrote:Thought panda had her rack replaced without removing the engine.
Yeah, I'm thinking saggy boobs to pert puppies.....
HahahahahaRichB888 wrote:hmm, well ill take a hit on replacing the pump first, at least the rack (I assume!) should be easy enough to replace even once the engine and box are back in.
You can remove without taking out the engine, difficult to get to the bolts. My mechanic did it though
Revo Tune + extra ME7 fueling - MTM TCU - Wagners - Koni Struts - DevilSown W/M - Michelin PSS's - Hotchkis Sways - Upgraded TC/Trans - Mugello/Black/Carbon
Ofcourse. You should hear my one about the swarfy slush box.Shoppinit wrote:Is that a euphemism?Nobby wrote:Thought panda had her rack replaced without removing the engine.
Daytona RS6 Avant
new PS pump resolved it for me. Thankfully wasn't the rack.
Users browsing this forum: Majestic-12 [Bot] and 357 guests
