Those with small plates
4.2 V8 32v FSI - 444 bhp
Macdaddy
Post by Macdaddy » Sat Feb 28, 2015 5:07 pm
Those of you with smaller front plates, How are you attaching them to the grill?
I've just and my plates made up, Don't really want to just stick them to the longer front plinth.
B7 RS4 Cabriolet with custom Blueflame - Gone
Misano red RS3 running Stage 1 APR - Gone
Sepang B8 RS4 with buckets - Gone
Panther Black C7 RS6 - Current Daily
kent_andy
Re: Those with small plates
Post by kent_andy » Sat Feb 28, 2015 6:52 pm
on my C6 I took the longer plinth off, then drilled the plate to align with the holes that hold the plinth on, I remember doing something similar with the b7 before.
alternatively you can get a plate holder that screws in the tow eye hole, I have that too but my small plate looked really really small when offset to one side, again slightly different on the B7
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
will1981
Post by will1981 » Sat Feb 28, 2015 6:55 pm
Macdaddy wrote:Those of you with smaller front plates, How are you attaching them to the grill?
Mine is just screwed straight on to the grill using the existing holes from the plate holder. Just use some longer screws and jobs a good'un' :thumbs:
2016 BMW F80 M3
2014 B8 RS4 - Milltek Non-Res - KW V2's with DRC delete - Setup by Centre Gravity. - Sold
2013 Q5 2.0 Tdi
1997 BMW E36 328i track car
Afsimba
Post by Afsimba » Sat Feb 28, 2015 7:03 pm
I'm in the process of buying a 4 digit plate and have enquirered with Audi and it's no trouble to get a short backing plate whether it's from US or UAE parts list I don't know but your local dealer can supply :nogarors4:
RIV
Post by RIV » Sat Feb 28, 2015 7:07 pm
Do you move the plate holder to one side to remove?
Vodkaking77
Post by Vodkaking77 » Sat Feb 28, 2015 11:54 pm
I used the holes for the plate holder and the same screws.
Currently my plate is in my window cos i love the massive grill. Looks meaner.
First pic with small plate
Now with in the window
ANDYRS#3
Post by ANDYRS#3 » Sun Mar 01, 2015 3:24 am
I used the original back plate and cut out the middle section with a chop saw, masked it all up first with duck tape so it didn't split when I cut it.
I also purchased a spare one from Audi just incase £76, but will need it anyway when I go to sell.
Current 2014 RS4 Sepang with optics, buckets.
997 Turbo Cobalt Blue
Previous:-
996 C4S
B7 RS4 Avant Sprint blue
B7 RS4 Saloon Sprint blue
MK5 Golf R32
MK4 Golf R32
Evo 8 & 6
Many golf GTI's
Macdaddy
Post by Macdaddy » Sun Mar 01, 2015 10:45 am
Plenty of options suggested thanks :thumbs:
Also prefer it without a plate tbh.
Mike82
Post by Mike82 » Tue Mar 03, 2015 11:01 am
I removed the plate holder and measured the holes on the car where the plate holder was attached to correspond to my new plate. Then drilled and fitted them into the original holes on the car.
however I did not like where the screws showed on my plate as it was half on the black lettering and half on the White back ground.
I then decided to get the pressed metal plates as I like the look of them. In order for me to attach this to the car without drilling the new pressed plate I counter sunk the holes on my old shortend plate and stuck the new pressed plate directly on top off it.
The pressed plate hides the old plate perfectly and looks good.
U don't have to use ur old plate u can also just make a small bracket out of thin sheet steel or stainless, drill and countersink the two holes and stick ur new plate directly to the new steel holder. Which will also eliminate the need for screw caps showing on your plate.
Twelfboar
Post by Twelfboar » Sun Mar 08, 2015 5:28 pm
Mine fitted with front short plate and as per Vodkaking77 , used existing Audi backplate fixings and a lower placement. :D
Users browsing this forum: No registered users and 52 guests
