Fuel B7 RS4
WilkinsonRS4
Fuel B7 RS4
Post by WilkinsonRS4 » Fri Feb 27, 2015 3:28 am
So in simple terms what's better for both cleaning engine and/or performance:-
v Power or 99 Momentum!??
Modified standard exhaust Modified deflapped inlet manifold ported and polished
Head and valve decoke Performance K&N panel filter. Remapped. Lowered slightly (20mm) on KW performance springs Widened on 10mm spacers.
chris_m
Re: Fuel B7 RS4
Post by chris_m » Fri Feb 27, 2015 3:32 am
V power for me.
2006 B7 RS4 Mrc stage 2
2000 evo VI tommi makinen red
1999 Evo V 370bhp white
1995 e36 m3 3.0 green
1988 Saff cosworth 2wd white
N11LS_J
Re: Fuel B7 RS4
Post by N11LS_J » Fri Feb 27, 2015 5:59 am
To add another question into the mix, if my car has been mapped on Tesco 99 (by MRC), will switching to V Power have any negative effect?
(main reason is, the nearest Tesco is 11 miles away, nearest shell is less than a mile!!
Sorry to jump in on your thread OP
Instagram : n_i_l_s
MartayMcFly
Re: Fuel B7 RS4
Post by MartayMcFly » Fri Feb 27, 2015 8:18 am
The difference should be slight enough to not affect the mapping (not sure about Ultimate vs the 99s), but when they were all tested together V-Power was the most consistent tank to tank. I think it was Fifth Gear that did it, testing 5 or 6 petrols in a standard car, a performance car and a remapped car.
Ask Doug though, he'll know for sure.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
mf51y
Re: Fuel B7 RS4
Post by mf51y » Fri Feb 27, 2015 8:43 am
Mine is stock been using momentum for some time due to fuel vouchers every little helps :).....but have recently switched to V power. I reluctantly can say V power is definitely better slightly more mpg and more importantly feels stronger ?
Mugello blue avant black optics...Nearly standard...milltek resonated valved, spaced 10 rear 8 front☺
Ozzyz
Re: Fuel B7 RS4
Post by Ozzyz » Fri Feb 27, 2015 9:37 am
When my car was at MRC a couple of weeks ago i got a call from Ben asking me what fuel i had in the car. At that paritcular time there was half a tank of BP Ultimate, Doug had it on the rollers and he immediately noticed something wasn't running right after he had mapped it. They emptied out the tank of Ultimate and replaced it with momentum, apparently it made a substantial difference. Ben said as long as the fuel is minimum 99 octane its fine, so V power or momentum fuel it is, not BP Ultimate!
neilparf
Re: Fuel B7 RS4
Post by neilparf » Fri Feb 27, 2015 11:41 am
When my FS4 was in at MRC, I had V-Bstard in it and it ran 429 and the timing wasn't as high as expected. MRC rinsed out that, put Tesco99 in and it ran 433.8 484NM.
However, always 99 be it VBstard or Tesco99. Me, I prefer Tesco - it seems to go better but that could be placebo, who knows. MPG? What's that...
Gone but never forgotten:
Covkiller
Re: Fuel B7 RS4
Post by Covkiller » Fri Feb 27, 2015 10:07 pm
ARAL 102 Octane is the best by far !
The thing goes like bloody stink on this stuff, its a shame it's only available in Germany and get this it's cheaper than V-Power and Tesco Momentum.
Anyway I use Tesco. Higher the octane the faster it goes.
6 points on the license yesterday in court
:boohoo:
SPEED MATTERS your honours !!
Vroom vroom !
:rocker:
mark260684
Re: Fuel B7 RS4
Post by mark260684 » Fri Feb 27, 2015 10:48 pm
Hi guys.
Just thought I'd throw another one in the mix. I've worked in Motorsport at various levels for 12 years now. One day I decided to ask our fuel guy who supply's our race fuel what is the best pump fuel. He said........total excellium was the purest fuel you can buy. A lot of the others have nasty detergents in them which end up leaving nasty deposits in the engine.
We often used to have a few 50ltr drums left over when our race cars ran 108 octane which we had to dispose of :lol: I had a corrado 16v that used to go like stink on that stuff, and the smell out of the exhaust was something special.
B7 Sprint Blue RS4 Avant,
Milltek non res non valve cat backs,
Decoke,
034 Motorsport alloy intake flap arms,
Led interior bulb kit,
Led drls and side lights,
Covkiller
Re: Fuel B7 RS4
Post by Covkiller » Fri Feb 27, 2015 10:54 pm
Bloody hell fire get me some 108, I need it !!!!!!
:FIREdevil:
For sure the Aral 102 is good, the difference is so noticeable. The car is alive. God knows what it would be like on 108 octane.
andyg72
Re: Fuel B7 RS4
Post by andyg72 » Sat Feb 28, 2015 9:30 am
Really some of you guys feel a differance between a 98 Ron over 99 ron and in a Na car ?
I've used a 102 Ron over in Germany felt better but not mind blowing
Maybe you should buy some vp import racing fuel at 125 Ron ;)
My bro seen a 100 bhp gain ( turbo'd car admittedly )
Covkiller
Re: Fuel B7 RS4
Post by Covkiller » Sat Feb 28, 2015 11:03 am
BP is 97 & 2 Star is 95. Try putting 2 Star in, it runs like a dog. So I'd say although marginal 98 to 99 can be felt, especially when you're highly tuned.
:thumbs:
SuprSi
Re: Fuel B7 RS4
Post by SuprSi » Sat Feb 28, 2015 6:42 pm
Mine gets monumentum normally and occasionally vbastard. Theres not normally any difference but sometimes at quieter shell garages you get a 'bad' tank. Apparently the additives shell use to raise the octane go off fairly quick whereas ethanol in tesco fuel doesn't.
I can't wait to get some 102 in Germany!
esp_mm-270
Re: Fuel B7 RS4
Post by esp_mm-270 » Sun Mar 01, 2015 3:28 am
I used momentum on my Golf, remapper said it was a bit down and I should change to v-bastard. Been on that since I got the RS4, tried some momentum again and was pleased with the noticeable difference. Tried the second tank and she was running like a dog..... Not ever had that on v-bastard!
chuckiceman
Re: Fuel B7 RS4
Post by chuckiceman » Sun Mar 01, 2015 10:12 am
neilparf wrote:When my FS4 was in at MRC, I had V-Bstard in it and it ran 429 and the timing wasn't as high as expected. MRC rinsed out that, put Tesco99 in and it ran 433.8 484NM.
I agree, previous owner of mine said he always used VBstard and that's what I used religiously to begin with. But after reading the MRC related threads I started trying momentum and felt mine goes better. Like you say, could be placebo :bigblink:
2007 RS4 B7 Saloon
Phantom Black | Black Optics | MRC Stage 2 | Carbon Clean | De-flapped | Non Res Milltek | MTM Spacers |
Users browsing this forum: No registered users and 174 guests
