OEM RS6 C7 PARTS?
seb de la run
OEM RS6 C7 PARTS?
Post by seb de la run » Sun Jan 18, 2015 1:05 pm
do you have a website or adress, because, i test with the Vag Com and i have problem on ignition coil : message engine misfire.
in the same time i have a message dysfontionnement start and stop..alternator problem??
so i need :
8 ignition coil
8 spark plug
1water pump
thanks you for your helps
LittleDevil
Trader (Expired)
Re: OEM RS6 C7 PARTS?
Post by LittleDevil » Sun Jan 18, 2015 1:54 pm
Do you maybe have error codes from vag-com?
Kind Regards
Post by MikeFish » Sun Jan 18, 2015 2:34 pm
Isn't it still under warranty from Audi? Why don't you just take it back to the dealer?
seb de la run
Post by seb de la run » Sun Jan 18, 2015 2:42 pm
my dealer is in france and i live in reunion island 10 000km.
the reunion dealer is a robber...is price is too much expansive.
so could you help me?
seb de la run
Post by seb de la run » Mon Jan 19, 2015 5:19 am
nobody have a good address to order oem parts? :|
LittleDevil
Trader (Expired)
Post by LittleDevil » Mon Jan 19, 2015 7:10 am
seb de la run wrote:nobody have a good address to order oem parts? :|
I send you private message. Check on the top of the website.
BFT - John
Post by BFT - John » Mon Jan 19, 2015 8:29 pm
Hmmmm you are tuned. Make sure you don't have a map that is causing these issues.
2014 Audi RS6 4.0TFSi - Red/Sports Exhaust/21's
2004 Brabus SL K8 - Weistec Supercharger - 744bhp/753lbs Torque
2014 LR Defender XS
2014 RR Sport TDV6 HSE Dynamic
2003 Audi A8 4.2 LPG
Few others kicking around.
seb de la run
Post by seb de la run » Tue Jan 20, 2015 5:12 pm
my code default : sorry for my bad english
p0301 00 (237)
missfire cylinder 1
i have the problem just when the rs6 is tick over...
if rhe engine idle more than 15sec, i have the EPC and the motor light...and the car is jerky
but if i drive under 15sec the engine idle, i have no problem..the car is perfect.
i remove the map.
i test ignition coil 1 by 4 and no problem
i test spark plug and no problem
injector?
but the problem is just when engine idle more than 15sec... :bash:
BFT - John
Post by BFT - John » Wed Jan 21, 2015 10:57 am
How have you removed the map?
If you have removed the map I suggest ensuring all ECU's are wiped off DTC's and try again.
2014 LR Defender XS
seb de la run
Post by seb de la run » Wed Jan 21, 2015 7:33 pm
many thanks for your message.
i must to remove the tune, but i dont understand this :
i must to drive without dtc?
or i remove the tune when the dtc is off...
sorry but i choice mathematic in option...and must to choice english !!! :bowdown:
