Battery dead
Clarkmagpie
Battery dead
Post by Clarkmagpie » Mon Dec 08, 2014 10:37 pm
Well after a fine weekend and no troubles, came to start car yesterday evening and completely dead.
Jump started and took it for a decent run out.
Alarm set for 5:30am this morning and car turned over before dying.
What batteries have you guys got and what do you recommend?
Thanks,
Nick.
EcurieEcosse
Re: Battery dead
Post by EcurieEcosse » Mon Dec 08, 2014 11:07 pm
How often do you use your car?
I don't use mine that often, and the cold weather means the uses more power on start up.
I have used Bosch batteries in my cars which work well.
I also use one of these which keeps them topped up. Definitely worth getting. Has served me well over the years, and on sale now.
http://www.halfords.com/motoring/bulbs- ... ry-charger
Clarkmagpie
Re: Battery dead
Post by Clarkmagpie » Mon Dec 08, 2014 11:13 pm
Daily without fail! And usually a decent weekend run.
Had a few sluggish starts a couple of months ago and never since.
Nobby
Re: Battery dead
Post by Nobby » Mon Dec 08, 2014 11:17 pm
I've got a big ass Varta one - same spec as OE but probably half the price. Think I bought it from a camping/caravan battery website
Daytona RS6 Avant
Re: Battery dead
Post by bam_bam » Mon Dec 08, 2014 11:25 pm
Varta Silver. It's been flattened 3 times and revived with a CTEK MXS 5.0 in recon mode. The Varta is still going strong and it holds charge longer, the OEM Bosch just isn't as good and it's 18months younger than the Varta.
sweegie
Re: Battery dead
Post by sweegie » Tue Dec 09, 2014 12:35 am
^^ Varta Silver FTW!!1
Recycling dinosaurs for fun
ahoooga
Re: Battery dead
Post by ahoooga » Tue Dec 09, 2014 1:06 am
see if you can see any labels on your battery which might say what year and month it was built , if its original battery , its at least 10 years old now so its fooked anyway
Re: Battery dead
Post by chunky79 » Tue Dec 09, 2014 7:57 am
A new battery is only around £120 so might be worth just firing a new one in. Check your charging is ok too.
Oooo yeah, go for Varta as said above.
sweegie
Re: Battery dead
Post by sweegie » Tue Dec 09, 2014 12:59 pm
I paid 95 bucks, including delivery from Battery Megastore on Spamazon. Search for I1 - Varta Silver Dynamic Car Battery (020) and you'll find it.
Thought it was very reasonable TBH, and arrived within 2 days.
mavada
Re: Battery dead
Post by mavada » Tue Dec 09, 2014 1:16 pm
Varta VA0 DE 000 915 105 AK
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
SuprSi
Re: Battery dead
Post by SuprSi » Tue Dec 09, 2014 1:22 pm
What's the voltmeter on the dash showing while you're driving?
adsgreen
Re: Battery dead
Post by adsgreen » Tue Dec 09, 2014 1:31 pm
EcurieEcosse wrote:I don't use mine that often, and the cold weather means the uses more power on start up.
Being pedantic, but the cold weather doesn't use more power, it simply slows the chemical reaction in the battery making less amps available.
The charge is still there and if you warm the battery up then it'll burst into life (granted, not very practical).
Ironically, a cold battery also has a longer standby time - it loses charge slower.
Problem is once a battery drops below a certain level, small crystal form on the metal plates which further reduce the charge capacity.
A decent conditioner should be able to restore many batteries back to operational life. Although as said previously if approaching 10 years then probably worth investing in a new one.
Re: Battery dead
Post by bam_bam » Tue Dec 09, 2014 3:46 pm
When was the alternator done?
SuprSi
Re: Battery dead
Post by SuprSi » Tue Dec 09, 2014 3:50 pm
bam_bam wrote:When was the alternator done?
Rule 42? :)
Mine's gone way past 3 years so i reckon it's waiting for the most inopportune time to give up lol
Rupert
Re: Battery dead
Post by Rupert » Tue Dec 09, 2014 6:22 pm
adsgreen wrote: The charge is still there and if you warm the battery up then it'll burst into life (granted, not very practical).
Ha! That brings back memories of taking a battery out of an old snow-covered renault and warming it up in front of the fire for an hour. Worked a treat.
Users browsing this forum: Steve2003rs6 and 74 guests
