alarms/trackers
4.2 V8 32v Naturally Aspirated - 444 bhp
longy79
alarms/trackers
Post by longy79 » Sun Dec 07, 2014 12:17 am
Heyyy
just wondering if there are any car alarm specialists in the north wales/chester area
been reading about the obd port issues and want to get myself additional alarm
any help be appreciated
thanks
Rick_RS4
Re: alarms/trackers
Post by Rick_RS4 » Sun Dec 07, 2014 12:30 am
id cut the plug off and wire an inline plug and socket for when you need the obd, then leave the obd port at home somewhere
adsgreen
Re: alarms/trackers
Post by adsgreen » Sun Dec 07, 2014 9:27 am
Only thing to be careful of is that the obd port contains twisted pair wires for the data communications. If you and an inline port that's too cheap and nasty (not designed for networks) then you could upset the way the port works.
Iirc obd sockets don't work unless they have a solid +12v and ground feed on the ports. Putting a hidden switch on those feeds should do the trick but worth testing with VCDS first.
Return to “RS5 (8T) 2010–2015”
