19" BBS CH (8.5" 5x112 ET35) + spacers £425
Ross_T_Boss
Post by Ross_T_Boss » Thu Aug 07, 2014 9:25 am
These were removed from my C5 RS6 prior to sale. The tyres fitted should not be used - tread is on the wear indicators and one lost a chunk out of the inner edge and would probably fail pretty quickly on the road.
So please consider it wheels and spacers only.
Condition is reasonable, one was kerbed as seen in pics below the others have some light scratches particularly around the bolt holes. The BBS centres are OK but looking a bit faded. Ideally they could do with a refurb, which I may get done if these don't shift. Priced at £495 as-is including spacers (although I will give them a good clean).
RS2 - Ragussa Green. OEM 'Big Brake' upgrade, Neuspeed RARB, Wagner Intercooler, Wagner Exhaust Manifold, Hybrid Turbo, 3" Scorpion turbo-back exhaust
F31 335D Msport+ Touring - Melbourne Red
MK2 TTRS - Suzuka Grey, Black Optics + Carbon Mirrors, Miltek Race exhaust, APR IC, APR Stage2+
Ross_T_Boss
Re: 19" BBS CH (8.5" 5x112 ET35) + spacers £495
Post by Ross_T_Boss » Thu Aug 07, 2014 9:28 am
Just to add these are 2 of the wheels, just realised I don't have pics of the other 2 that are in similar condition but without any kerb rash. Will get a pic of the full set up on the weekend. This is a set of 4.
brent007
Post by brent007 » Thu Aug 07, 2014 1:10 pm
Hi mate,
Do you or anyone else know if these will fit my b7 rs4.
If so, where are you please.
Regards
Brent
tmg
Post by tmg » Thu Aug 07, 2014 3:04 pm
hey
what size spacers?
cheers
t.
Ross_T_Boss
Post by Ross_T_Boss » Fri Aug 08, 2014 9:24 am
Hi,
The spacers are 10mm so effectively ET25; worth mentioning that the spacers and the wheels go together as the hub is 57.1mm on the spacer but larger on the wheel. The hub ring on the spacers matches the wheel. I will also supply the longer bolts.
OEM on the C5 RS6 is ET35 so they sat 10mm further out. A bit of rubbing but she was sitting very low on coilovers, a 5mm rise resolved it. The filled arches and slightly wider track looked great too.
OEM for the B7 RS4 is ET29 so they would sit 4mm further out. I cannot say for sure, but I can't see that being an issue, best ask on the RS4 forum if anyone else is using spacers.
I am in Swindon but could help somewhat with delivery, I am occasionally travelling toward London/Bristol/Birmingham/Milton Keynes.
Ross
Ross_T_Boss
Post by Ross_T_Boss » Fri Sep 26, 2014 10:00 pm
Bump, still sat in my garage, open to offers as I need to clear some space.
Ross_T_Boss
Post by Ross_T_Boss » Sun May 24, 2015 8:57 pm
SOLD
Users browsing this forum: No registered users and 222 guests
