Cheap bluetooth streaming - External AV req
barryrs
Post by barryrs » Wed Jul 30, 2014 3:01 pm
Hi guys,
Thought I would share my recent cheap Bluetooth music streaming solution for others as looking on the web didnt turn up much.
Total cost of the install was just circa £45
The parts required are as follows
1. Connects2 CT29AU02 lead. I got mine here - http://www.ebay.co.uk/itm/160690745278? ... 1497.l2649
One thing to note is that there was a manufacturing fault with my first lead where the left and right negatives had separate pins when they should be joined giving you 5 pins to plug in.
Installation instructions are here - http://www.connects2downloads.co.uk/c2/ ... 29AU02.pdf
Although my layout looks different it was just a case of removing 3 nuts and 1 bolt and the whole cage lifted and swung into the boot for easy access.
2. Ipod to RCA including power lead here - http://www.ebay.co.uk/itm/130733565203? ... 1497.l2649
You simply need to locate a suitable live and earth point in which to wire this in and connect to the above lead.
3. Generic Bluetooth receiver such as - http://www.ebay.co.uk/itm/221402870065? ... 1497.l2649
This receiver needs a power source as the lead above and negates the need for battery’s
4. Generic CAN-BUS ignition generator as theres no switched live in the boot - http://www.ebay.co.uk/itm/150375318803? ... EBIDX%3AIT
All in all a very simple install and works perfectly with my factory fit telephone prep by fading out the music when a call is received and continuing once the call has ended.
Well pleased :rocker:
Rs4andy
Re: Cheap bluetooth streaming - External AV req
Post by Rs4andy » Sat Jan 10, 2015 6:32 pm
hi just received all the parts required but not sure what colour wire goes in which pin on the plug can you help Thanks Andy
Return to “Electrical”
