Is this safe to drive on
Drove out to country pub for carvery and noticed this on front near side tyre . Don't want a blow out, no damage to tyre or alloy, just noticed the bulge which isn't apparent on any other tyre
She may be big and heavy but its whats on the inside that counts.....
Re: Is this safe to drive on
Ekkkkkk.......if its not too far then drive home very carefully and then get a new pair is what I would do
Not good is that bulge
950 nm torque!
Ohh running bridgestones because they are the best
Top toe is the key. As above that is a failed unrepairable tyre.
If there is no air being lost the my money is on one or more failed steel cables (that near the bead suggest could be that one and that holds the tyre to the rim)
Otherwise it could be the inner canvas failed and is pushing the outer rubber into a bulge.
Either way that is something to not drive on and certainly not motorway speed.
Holy moly... Send the wife and kids back in a cab
More importantly, clean that filthy wheel immediately you mucky git!!!!!!
Will do
Nowhere seems to stock ps2s , is it worth /safe/compatible to get ps3s across the front (ao designation) and ps2s on rear(ro1 designation). My own thoughts would be avoid and keep all 4the same but didn't know whether there was that much of a difference between ps2 ro1 and ps3 ao to cause transmission wear
If I remember correctly the PS3's are not as good as PS2 - seem to recall they had worse wet performance than the PS2's in the wet. In which case if I had to have them, I'd be inclined to put them on the rear and keep the PS2's on the front.
I just Googled and it looks like Black Circles have the PS2's in stock - have you actually searched on line, or just rung local stockists??
EcurieEcosse
- 2nd Gear
I got my PS2s recently from Tyreleader. Great service. They have them in stock in the correct R01 fitment at £154 each. Sure I paid more than that.
http://www.tyreleader.co.uk/car-tyres/m ... -96y-47145
196 x 2 fitted with black circles. Every other garage I approached including Audi say ps2s on back order so let's see if black circles can deliver as promised . Full refund or reschedule if not here on time.
- iaingbrown
- 1st Gear
Nope. Set of for Unit 20 from Glasgow; had battered deep pothole from the bad 2010 winter with nearside front. En route the car was vibrating and mayhem. Pulled off the road and had a right good look. Couldn't see anything. It was the carcass of the tyre bashed and bulging from the trauma of the pothole but all on the inner surface.
Immediately spotted by Martin and a 'get home' tyre for free to get home and get full replacements.
How was the carvery?
Users browsing this forum: philS2 and 1409 guests
