Rs4 saloon rear doors
Littlerick
Might be a stupid question but are rs4 estate Rear doors the same as saloons some twats dented mine right on the crease and have managed to source a door off a estate in same colour please help as meant to be collecting weekend
Re: Rs4 saloon rear doors
Littlerick wrote:Might be a stupid question but are rs4 estate Rear doors the same as saloons some twats dented mine right on the crease and have managed to source a door off a estate in same colour please help as meant to be collecting weekend
Without looking at a picture I'd imagine the top of the door is different as the roofline on an avant keeps going but on a saloon it drops. The B8 is definitely different, I'd imagine this would apply to the B7 too.
- MartayMcFly
- 5th Gear
Yes, they're very different unfortunately.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
A body repair specialist would be able to tap it mostly out, sand, filler and re-spray for less than you'd probably pay for a whole door.
Rs4 outer door shells are plastic - can't tap out
the doors are the same, its just the top frame that is different, but this can be swapped easy enough.
I had a new rear door due to an altercation with a deer recently - the door is all metal...adsgreen wrote:Rs4 outer door shells are plastic - can't tap out
The saloon door and Avant door are the same - as sar mentions it's the top that's the difference but one can easily switch with existing door ancillaries.
New rear door from Audi (unpainted) is £446...
Gone but never forgotten:
Mine are definitely plastic - had a new set on drivers side when got clipped by stupid driver.neilparf wrote:I had a new rear door due to an altercation with a deer recently - the door is all metal...adsgreen wrote:Rs4 outer door shells are plastic - can't tap out
You can tap them and push them in quite far and the flex easily.
Finally I have a car park ding that is (about to be fixed) through to the undercoat and you can see the plastic underneath.
very strange?, mine are 100% steel.adsgreen wrote:Mine are definitely plastic - had a new set on drivers side when got clipped by stupid driver.neilparf wrote:I had a new rear door due to an altercation with a deer recently - the door is all metal...adsgreen wrote:Rs4 outer door shells are plastic - can't tap out
Littlerick
So the door is the same and i can change my frame 100%
Finally I have a car park ding that is (about to be fixed) through to the undercoat and you can see the plastic underneath.[/quote]
Ditto. I even saw the Audi rings on the sticker and part number etc. on the bare door.sar wrote:very strange?, mine are 100% steel.
Ads - are they Audi exclusive or something for weight?????
KernowPete
Mine are defo steel - just been out and checked with a magnet
2007 B7 RS4 Phantom Black Saloon - stock
Previous: Lightly modded Mondeo ST220 (great car), nothing else worth mentioning!
Mine are metal too, I know cos I've covered them with sound deadening.
- esp_mm-270
Definitely not carbon on mine.esp_mm-270 wrote:Mine too. But I have heard you can get c/f doors "Or did I dream it...."?
composite perhaps?
Users browsing this forum: Bing [Bot] and 329 guests
