What does everyone use to resolve a Squeeky door?
Obviously i could use WD40 but wanting a long term fix
Squeeky Door
Squeeky Door
A7 3.0T - Pretty Std at the moment... in warranty
VW Caddy 2k 1.9 TDI - Std
Has beens:
C5 RS6 Avant - Wagbo'd, PSS9, MiIltek Res, MRC Stage 2, ACE Torque Converter, 551ps 815nm | 00 B6 A4 2.5TDI | 01 Nissan R34 GTR V-Spec (UK) | 93 Toyota MR2 GT | 95 Mitsubishi FTO | BMW 318is | Vauxhall Corsa 1.4 16v SRI | Vauxhall Nova 1.3SR Chavtastic
Has beens:
Re: Squeeky Door
White Lithium grease on the offended section would cure it.
- Drummerman
- 2nd Gear
Re: Squeeky Door
How about a squeaky window?? Passenger window has started making hell of a noise when opening. Sorry to jump on your thread
- Mr Footlong
Re: Squeeky Door
Drummerman, I have the exact same problem, started a few months ago. It is loud enough to turn heads from 20-30 feet away if I dare open the window. 99% sure it is from the front side of the window seals. Once you get to around 1/3-1/2 down it stops.
Current:
Gone:
Gone:
Re: Squeeky Door
Silicon spray lubricant from Halfrauds.
But it might be a regulator that needs lubing (just before it lets go).
Re: Squeeky Door
I have a squeaky doorhandle
RS2 -94: RsBlue, 622whp/719nm, E85, 2,5l, PT5862, MTM 8,5x18"...
RS4 -01
RS4 -01
- Mr Footlong
Re: Squeeky Door
Thanks, I will give that a go when I get a chance, as long as it doesn't foul the window with gunk or risk damaging the front tinting filmShoppinit wrote:Silicon spray lubricant from Halfrauds.
Current:
Gone:
Gone:
Users browsing this forum: Google [Bot] and 234 guests
