air conditioning compressor whine
philipinoz
Post by philipinoz » Mon Jun 16, 2014 4:25 am
Ok, rather than resurrecting my year old (almost to the day) posting (http://forum.rs246.com/viewtopic.php?f=2&t=104448), an update.
First off, lesson learnt. I should have just got the thing sorted a year ago when it first started. :bash:
But it wasn't constant whine, just sometimes, and then it'd go away again. Shrug. And the a/c was mostly working, although the control panel buttons were getting really hard to use.
Having a bit of spare time, and just getting a bit irritated by the control panel and by the coming and going whine, brought the car to an a/c specialist last week.
The voicemail message back from them was "don't drive the car, we think the compressor could disintegrate any moment" was scary - and followed up this morning with the repairer confirming that the compressor was beyond any economical repair (shaft had disintegrated).
And the non-working buttons on the control panel actually were caused by the micro-sensors in the board underneath being completely broken (and apparently not the sort that can be repaired/replaced).
Getting a replacement a/c compressor here in Aussie seems doable (those things are not cheap, even reconditioned), but it might be harder searching for a control panel. I'm guessing the eBay sort would be 'buyer beware', as they would have come off cars of similar vintage and therefore would be suffering from the same button failure?
Anyway... I need to upgrade my RS6 owner's existing paranoia about funny noises from under the bonnet!
philip
2014 RS6 (Daytona Grey)
Previous Drives: Astra -> Cavalier SRi -> Audi 90q -> A4 2.8q -> A4 2.4q -> Mercedes ML430 (Carlsson) -> RS6 C5
Maximo
Re: air conditioning compressor whine
Post by Maximo » Mon Jun 16, 2014 8:16 am
I've bought a replacement control panel off ebay, it didn't come from an RS6 though so needed to be coded to the car. Other than that it's been fine.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
philipinoz
Post by philipinoz » Tue Jun 17, 2014 5:07 am
Thanks Maximo. Coded to the car? Oh gee. :-(
Well, I got the car back today, replacement compressor in place, very cold a/c (it's never ever been like this). Plus the buttons on the control panel seem to be working again (hmmm). I'll work away with the current panel for now - AU$2500 was the quote for a new one (approx £1400), a lot of money to fix two buttons not working 100% of the time.
Maximo
Post by Maximo » Wed Jun 18, 2014 9:39 am
All good stuff then. The coding isn't to difficult, you just need to plug in your Vagcom and go to the module. I'm sure you'll work it out from there. Check out ross-tech for help with what coding you'll require. Although I'm sure there has to be more than one Ozie based car on here.......
Users browsing this forum: Google [Bot] and 369 guests
