Replacing interior monitor switch
pete62
Post by pete62 » Sat Jun 14, 2014 6:06 pm
Anyone replaced the interior monitor switch from the drivers side pillar?
The switch part seems to have disappeared from mine and I was wondering if it is as simple as remove the old one unplug and plug in new one and replace.
amanda1
Re: Replacing interior monitor switch
Post by amanda1 » Sat Jun 14, 2014 6:11 pm
I have
950 nm torque!
seaneb
Post by seaneb » Sat Jun 14, 2014 6:22 pm
Yes it is easy to do but easier if you remove the trim along bottom of door aperture and then loosen the pillar trim. You can then squeeze the retainer clips in and push the switch out.
PREVIOUS: Black Audi B6 S4 Avant. Custom exhaust (sounded amazing). Otherwise standard and near perfect.
PRESENT: Muggy '53 RS6 loon. MTM Stage2. KW3s. 100 cells. Milltek.
pete62
Post by pete62 » Sat Jun 14, 2014 6:33 pm
Amanda1 very amusing if not very helpful
Seaneb thanks for that ,I assume you mean the long plastic trim that goes right along the door aperture.how is that held in?
seaneb
Post by seaneb » Sat Jun 14, 2014 8:53 pm
Yes I mean that one. It's one piece right along front and rear doors. I can't remember how it comes off but I do know that it was pretty straight forward.
lapman
Post by lapman » Wed Jun 25, 2014 4:29 pm
Hi, I have exactly the same issue with a busted switch. I wondered what it was. Is there a part numbers as I will have to get a new one as well?
lapman
seaneb
Post by seaneb » Wed Jun 25, 2014 4:46 pm
I just went to local VW dealer (Audi are quite far away from me), they switched their parts catalogue over to the Audi one, found it on a drawing and ordered.
pete62
Post by pete62 » Wed Jun 25, 2014 8:25 pm
Part number for mine was 4B0 962 109 A easy to fit no need to lift the door sill trims just insert thin bladed knife carefully in either side (as that is where the retaining clips are) and pop out and change over.
I got one of eBay for a ten near . Not sure how much a new one is :thumb:
lapman
Post by lapman » Thu Jun 26, 2014 11:50 am
ok thanks, I'll order one and give it a go.
Users browsing this forum: No registered users and 308 guests
